1/32 Me262A-1a/U4 (JV44 Hunters and Protectors Project)
  • adt70hk
    • Sep 2019
    • 10402
    #166
    Originally posted by AlanG
    Turbine control linkage made. Much swearing involved. Especially as most of it 'pinged' across the room at various points or superglued itself to the tweezers
    [ATTACH=CONFIG]n1195873[/ATTACH]
    Oh my...... Rather you than me!!
    • Mini Me
      • Jun 2018
      • 10711
      #167
      That is a nice bit of "Knicky Knackery" there Alan should add greatly to the overall effect. :thumb2:
      • Caustik Filth
        • Jan 2022
        • 364
        • Rob
        • Portsmouth
        #168
        Exquisite detailing Alan, loving it!
          • 18892
          Excellent upgrades Alan. Really lifting this higher and higher.
          • AlanG
            • 6296
            #170
            Linkage (partially) fitted as i've just broken off a control rod from it. Will glue that back on tomorrow night. Fitted a couple of pipes and made a new t-valve for the bottom pipe. Will paint these ones up now and then add the others on top afterwards. Not toomuch left for this front section now (thank heavens).
ID:	1196624Click image for larger version
            • yak face
              • Jun 2009
              • 13829
              • Tony
              #171
              Superb work alan , its going to look amazing , cheers tony
              • Mini Me
                • Jun 2018
                • 10711
                #172
                PITA....PITA....PITA..... :thumb2: I'm pleased that you're not pulling your hair out Alan and the detailing is really the BomB Sir!
                • JR
                  • May 2015
                  • 18273
                  #173
                  Can't get much better than this Alan.
                  • adt70hk
                    • Sep 2019
                    • 10402
                    #174
                    Ditto that John. A work of art!!
                    • AlanG
                      • 6296
                      #175
                      First set of pipes glued in place and painted. Makes it 'pop' a little more i think.
                      Three more pipes to go and then i have two filters and a few braided electrical cables to paint silver and that is the front section completed bar a few little areas to touch up with the aluminium paint. Then it's onto the middle section. All that needs is priming and painting, The rear section just needs painting.
                      Then it's onto joining the sections together and fitting various cables in place
ID:	1197016Click image for larger version
ID:	1197018Click image for larger version
                      • adt70hk
                        • Sep 2019
                        • 10402
                        #176
                        That's brilliant Al. Really looking the business. Very well done.
                        • AlanG
                          • 6296
                          #177
ID:	1197492Click image for larger version
ID:	1197493Click image for larger version
                          • adt70hk
                            • Sep 2019
                            • 10402
                            #178
                            Is it finished Al? Really looking good!!
                            • AlanG
                              • 6296
                              #179
                              Originally posted by adt70hk
                              Is it finished Al?
                              Not yet. Still need to add 3 pipes on the front section. I am waiting to paint the middle and rear sections as i have some filler drying
                                • 15669
                                That is a thing of beauty Alan. A real tribute to your patience and skills.
