1/32 Me262A-1a/U4 (JV44 Hunters and Protectors Project)
  • stillp
    • 8091
    • Pete
    • Rugby
    #61
    PVA will probably work as well as anything.
    • Allen Dewire
      • 4741
      • Allen
      • Bamberg
      #62
      Great scratchy Alan!!! Really liking this and what you are doing here....
      Allen
      • yak face
        • Jun 2009
        • 13837
        • Tony
        #63
        Top work alan , love the twin and earth combustion chambers , im a great believer in using everyday materials if possible , its surprising what you can use if you just think outside the box a bit
        • adt70hk
          • Sep 2019
          • 10406
          #64
          Originally posted by AlanG
          So why the mathematics? Well i had to work out what size the six combustion chambers of the Jumo 004 would have to be to fit inside the Revell depiction of the engine so that you could 'see' two chambers in each hole i drilled out. Took a bit to work out and to try and find something that i had readily available to use. I could have bought something off evilbay but the prices i were given imho weren't justifiable. Any how. Here is my progress
          [ATTACH=CONFIG]n1191640[/ATTACH]
          [ATTACH=CONFIG]n1191639[/ATTACH][ATTACH=CONFIG]n1191638[/ATTACH]
          Brilliant!
          • AlanG
            • 6296
            #65
            Little more scratch building tonight. Taken a night off from the engine whilst i figure something out. So back onto the rear of the instrument panel. The pneumatic pipes that will come from the accumulator that i built go into three different instruments at the back. So i have made three t-joints for pipework to connect to. These were made from wire flex. As you can see, one is still to be cut to size.
            • AlanG
              • 6296
              #66
              Those little t-joints help me do this....
              • adt70hk
                • Sep 2019
                • 10406
                #67
                Now that is looking very, very good indeed!!
                ATB.
                • AlanG
                  • 6296
                  #68
                  Actually i wasn't pleased with it. I think the t-joints look to big and fat. So after a hunt around in my old cable draw, i found some smaller flex to make them out of. And here are the results. First pic is of the two joints side by side. As you can see the white one is a lot smaller. Second is of the new t-joints fitted. Now that is a lot better imho :smiling3:
                  • AlanG
                    • 6296
                    #69
                    An unused bit of PE 'sprue' to make an electrical bracket. Some 0.2mm wire and [COLOR=rgb(184, 49, 47)]SO[/COLOR] much patience. And it starts to come together. I sometimes wonder why i let my OCD take over when it comes to building models. It would be so much easier OOB.
ID:	1193161Click image for larger version
ID:	1193162Click image for larger version
ID:	1193163Click image for larger version
                    • scottie3158
                      • 14201
                      • Holbeach
                      #70
                      I know what you mean :smiling:
                        • 18901
                        So do I, but I’ve managed to curb it over the last few years. Does lift them though doesn’t it…..this looks fabulous Alan :thumb2:
                        • AlanG
                          • 6296
                          #72
ID:	1193165Click image for larger version
                          • adt70hk
                            • Sep 2019
                            • 10406
                            #73
                            You're attention to detail on this is first rate.
                            Well done Alan!
                            • Steven000
                              • Aug 2018
                              • 2827
                              • Steven
                              • Belgium
                              #74
                              Great details Alan, have fun :thumb2:
                              • Mini Me
                                • Jun 2018
                                • 10711
                                #75
                                Alan.....OOB is Boring! anyone can do that, just let your creative juices flow while others stand by and wish that they could do that.
                                Oh and by all means, enjoy yourself while doing so.
