Ole , dont forget that ailerons were opposite in action, If one was down the other side would be up. cheers tony
started lancy
Even at rest the ailerons would still be opposite to each other , ie. one up the other down , if the glue isnt too set it should be easy enough to move one into the upright position . The elevators however can both be positioned deflected downwards. cheers tonyComment
after yakface aka tony said about ailerons ive fixed them [ATTACH]40507.vB[/ATTACH][ATTACH]40508.vB[/ATTACH]wooosh glue was till tacky
mobear
[ATTACH]44195.IPB[/ATTACH]
[ATTACH]44196.IPB[/ATTACH]
Ole this is looking fantastic! Love the weather effect around the ailerons, what did you use to create that effect?Comment
i use oil paints in differing ammounts of thinner then just before it starts to dry properly i add black oils in creases,and thnx for compliment
mobearComment
just airbrushed the underside left it overnight to dry i`m quite happy with the result,[ATTACH]40604.vB[/ATTACH]
mobear
[ATTACH]44283.IPB[/ATTACH]
camo is done just need to weather it slightly and clean up some edges,Then it`s decal time [ATTACH]40764.vB[/ATTACH][ATTACH]40765.vB[/ATTACH]
[ATTACH]44436.IPB[/ATTACH]
[ATTACH]44437.IPB[/ATTACH]
