Hasegawa 1/32 Spitfire MkVI High Altitude fighter.
  • rtfoe
    • 9088
    #16
    Whoah...John, thank you. What a comment...I hope I don't falter along the way. :smiling2:
    Just painted the scratched seat belts. Still need to drill the other two belts and paint the eyelets.
    I think they need lightening a bit.
    • JayCee
      • Aug 2019
      • 1132
      #17
      Very nice, Richard. Extremely clean painting in the "pit".
      John.
      • rtfoe
        • 9088
        #18
        John.
        Thanks John...cleanliness is next to a nice looking cockpit. :tongue-out3:
        Closing her up now after I glue on the sight.
        Had to drill the right side of the seat to take the bottom seat belt. Funny thing is the left doesn't have the hole.
        • rtfoe
          • 9088
          #19
          Hi again, just checking the dehydral by applying tape...
          Then realising that everything basically is partially hidden except for the seat and harness detail.
ID:	1186235Click image for larger version
            • 15709
            That cockpit looks superb Richard. Looks as if the fuselage halves have gone together well.
            • rtfoe
              • 9088
              #21
              Thanks Jim, I'd forgotten how well Hasegawa kits come together having always choosing other difficult fitting brands all these years. The last time I built one was when I was still in art school. I like the way they engineered the fit of the wing to the bottom of the fuselage which left sanding to a minimum.
              • rtfoe
                • 9088
                #22
                Hi,
                After some minor filler and sanding plus a coat of Mr Surfacer primer, I pre-shaded with a light shade of Nato Black. Didn't want it to be too dark as the top coat will be light Neutral grey. The underside was heavier to take the PRU blue.
                  • 18911
                  Originally posted by rtfoe
                  Hi,
                  [ATTACH=CONFIG]n1186351[/ATTACH]
                  Good work Richard. Looks weird with those pointy ears though….
                  • Mini Me
                    • Jun 2018
                    • 10711
                    #24
                    Hi Richard, I use Rubber (elastic) bands to check/set dihedral on my wing sets as it exerts more equal pressure/tension on both wings. It can also be adjusted by the size of the band you use. just a thought while eyeballing this beautiful build. :thumb2:
                    • rtfoe
                      • 9088
                      #25
                      Thanks Tim. Mr Spocks personal ride.:tears-of-joy:
                      I'll make a note of that Rick, thanks.
                      • yak face
                        • Jun 2009
                        • 13841
                        • Tony
                        #26
                        Excellent stuff richard , its looking great . The cockpit looks lovely , top work improving the seat . The older Hasegawa 1/32 kits are still a great build , as you say not overly complicated parts wise but still nicely detailed . I remember doing the me163 as a kid and that was a beauty too . I always liked the high altitude spitfires with their pointy wings , something a bit different from the norm , cheers tony
                        • rtfoe
                          • 9088
                          #27
                          Well I've missed the deadline but will persevere. So far these are the items I will be putting together...
                          Firstly it's the cut stencils from masking taped with the help of a photo copy tracing...
                          While doing that I had the canopy parts dipped in Future and let dry...
ID:	1186658Click image for larger version
                          Glued the wheel halves and sanded the joints.
ID:	1186660Assembled the prop blades to the hub and spinner making sure they were aligned.
                          Masked all openings...
ID:	1186662Click image for larger version
                          Taped up the no step perimeter lines as no decals were given for it. Then getting the stencils aligned on the fuselage.
                          Next to mask the canopy but will show some of the displays on that day later.
                          • rtfoe
                            • 9088
                            #28
                            Thanks Tony,
                            You're the odd one out as nearly everyone felt the pointy tips a bit weird for a Spit. Different from the norm yes it is.
                            The old Hase kits are great builds apart from the raised panel lines which make pin washes a little difficult. I got delayed with the scribing.
