Pete's Beaufighter
Looking good Peter. Nice use of BMF for masking. I’ve only ever used that stuff on car build chrome trim, for which it is excellent. Doesn’t the glue bond get stronger with time though? Just wondered because I can imagine a time in a protracted build where the foil becomes impossible to remove cleanly at all.Comment
Added some more clear bits:
The landing light went in easily. The wingtip lights were a pain though - they're tiny, and the shape is difficult to hold. Got them on after a bit of a struggle. Using the Formula 560 canopy glue that I found in an "everything £1" box at the St Ives show. It's runnier than the Gator's Grip I usually use, but Gator's is an endangered species of glue since the California wildfire. :disappointed2:
Also painted up the rockets and assembled the rocket rails, which will get a coat of paint tomorrow with a bit of luck.
The main gear wheels are already painted:
I removed the navigator's canopy and masked his cockpit with wet tissue instead. I haven't decided whether to use the closed undercarriage doors as a mask for the u/c bays, or to fill the bays with wet tissue.
PeteComment
Starting to splash some paint on:
Masked with a mix of tape, wet tissue, foil, and masking fluid. Got a bit carried away with the fluid though:
Spot the mistake?
The rearmost light on the wingtip is a recognition light, and only the small cylindrical part that sticks out at the back should be clear, the rest is shrouded so didn't need masking. The fluid (Mr Masking Sol R) came off alright, but the clear lens came away from the wing, so no more painting until the glue sets on that!
PeteComment
... See what I did there?!!
I just like these planes,and I think it's coming threatComment
Bare-Metal Foil, casting resin, silicone rtv mold rubber, polyurethane mold rubber, Decals for model a/c, Bare-Metal Panel Scriber, Experts-Choice Decal Film, and Microscale modeling liquids.
It’s primary use is for recreating chrome trim on model cars. You cut a suitably sized piece out, stick it over the trim area, burnish it smooth with cotton buds and blunt implements, then trim off the excess with a new scalpel blade. It is actually much simpler than it sounds and is very effective, much more so than trying to paint the trim. You get a sharper and more “chrome like” appearance using it. It comes in several colours as well.
Pete is using it here in a similar fashion to mask the cockpit glazing. Far easier to get it into the corners than using masking tape, and it cuts cleaner when in place.Comment
It is more or less exactly what it sounds like John. BMF is a self adhesive thin metal foil.
I must admit it took me some thought to work out what BMF was supposed to be when I first read it in this thread, and then I remembered that a lot of the old modelling handbooks mentioned “bare-metal foil” for the purposes Tim and Karl described, and the penny droppedComment
