Yokosuka E-14Y ‘Glen’ with catapult
  • flyjoe180
    • Jan 2012
    • 12400
    • Joe
    • Earth
    #46
    Looking forward to seeing this Tony, awesome stuff
    • Mini Me
      • Jun 2018
      • 10711
      #47
      Now that's different.... :thumb2:
      • Neil Merryweather
        • Dec 2018
        • 5189
        • London
        #48
        Ooh exciting !
        • yak face
          • Jun 2009
          • 13841
          • Tony
          #49
          Now heres where it starts getting a bit messy and mr Dewire starts getting excited! Ive carved and sanded the main hull (pink foam) to shape and started on the other parts . I managed to procure an offcut of insulation off a building site I was delivering on which is thick enough for the next step. This was easily carved to shape and sanded to form the Hangar ( the bit that looks like a well licked choc ice! ) and the conning tower ( the bit on top of it) . The decks had wooden planking up to a point so to replicate this I‘m using plastic card , lightly scribed with a P cutter to form the planks .
          BTW , is this the worst submarine ever ? Its made out of polystyrene foam - it’ll NEVER sink !!Click image for larger version
ID:	1189385Click image for larger version
ID:	1189386Click image for larger version
ID:	1189387Click image for larger version
ID:	1189388Click image for larger version
ID:	1189389Click image for larger version
ID:	1189390Click image for larger version
ID:	1189391Click image for larger version
            That is a very cool idea and well built.
              • 15698
              Very good Tony. I imagine it's a very messy process :smiling:
              • JR
                • May 2015
                • 18273
                #52
                Most impressed Tony with use of the insulation foam, and free to boot , always makes it better . What do you use to fill and get such a smooth surface ?
                • KarlW
                  • Jul 2020
                  • 1522
                  #53
                  Just caught up wwith this, very impressed with the sub base.
                  I think there was a parts work to build the I-401, very impressive sub with an equally impressive hanger, the circular hanger door was very distinctive.
                  • The Smythe Meister
                    • Jan 2019
                    • 6248
                    #54
                    Still watching from the cheap seats Tony
                    Great idea,and coming along....
                    .... Looking forward to watching this develop
                    • yak face
                      • Jun 2009
                      • 13841
                      • Tony
                      #55
                      VERY messy jim ! It sands very easily , being just a bit firmer than florists oasis . Creates lots of fine dust that is very clingy, you have to be careful when holding it too , its easy to grip too hard and leave imprints .
                      Nothing as yet john , it just sands to a really smooth surface . Its still a bit porous though so the whole thing will have to be sealed with PVA or similar before painting ,cheers tony
                      • adt70hk
                        • Sep 2019
                        • 10409
                        #56
                        Tony,
                        Just had a catch-up. The plane has turned out beautifully and love the way you're taking it now.
                        ATB.
                        • Geoffers
                          • Jan 2017
                          • 1703
                          • Geoff
                          Just catching up Tony, the aircraft looks great, I really like the colour scheme :thumb2:
                          Can’t wait to see it on the sub, you are taking this build to another level :surprised:
                          Geoff.
                          • rtfoe
                            • 9086
                            #58
                            Very nice build of the Glen, Tony and progress on part of the sub. What will you use to stiffen the foam...perhaps some resin after the pva coating.
                            Richard aka Wabble
                            • yak face
                              • Jun 2009
                              • 13841
                              • Tony
                              #59
                              Richard aka Wabble
                              Its fairly stiff richard just a bit porous , ive been experimenting on some offcuts and i think 2 coats of pva will be enough to smooth and seal it before the primer goes on . cheers tony
                              • KarlW
                                • Jul 2020
                                • 1522
                                #60
                                I've used it for wargaming terrain and a coat of emulsion was usually enough. That's basically coloured PVA.
