Yokosuka E-14Y ‘Glen’ with catapult
The hangar has had a quick coat of Halfords grey primer and this highlighted a few pinholes , which you dont want in a submarine! These have been touched up with grey acrylic , and once dry it will be getting a coat of the black primer. A thin strip of tamiya tape was stuck on at the front to represent the joint of the hangar door .Comment
ThanksTony, did think that the yellow was a soft and more coarse insulation foam then the pink. I recently tried to cut a section while practicing with a hot wire cutter. Trying to cut it with a knife was not much better, it crumbled.Comment
Its one of the only things that works sticking the foam together . I tried superglue - melted it , pva - wouldnt stick , UHU hart - melted it , poly cement - melted it . This no more nails is a water based one , very handy for cleaning up joints and so can be used as a caulk too. Cheers tonyComment
