Spitfire Mk. 22/24 (Revell, 1/32)
    Lets gooo again
    My wife will me
    Roman
    That will be large at 1/32.
    Roman do you actually get any sleep ?
      Originally posted by \
      That will be large at 1/32.Roman do you actually get any sleep ?
      yes I get some sleep, today from noon til 2PM
      all last night was awake finishing an-2...
      But I think today I will have day off
      Roman
      • stona
        • Jul 2008
        • 9889
        I've made one of these along with several of the masochists who frequent this forum
        Good luck! You will need it but I'm sure you will beat it.
          hey roman,i`m trying to get my pilots arms to move if you fugure out a way let me know,also there is a mk22 spitfire with the prefix CROS on the side which still flies today,which i`m changing mine to if i can find more decals,maybe you will beat me to it LOL
          cheers mobear
            • 18266
            Roman my man you are on a roll.
            I too am sure you will whip this into shape, When your wife is finished whipping you into shape that is!!!
            Ole, that Spitfire you mentioned, CR*S is a privatly owned Spit and the codes are the owners OWN so its not an airforce coded aircraft.
            If you Google- TD248 spitfire - in pictures, you will get a mass of pictures of the Aircraft serial nr TD248 and all the schemes she has worn since restoration.
              good god you know way toooooo much ian though i think it looks awesome and keeps spits at the forefront of aviation of old
              cheers ole aka mobear lol
              • colin m
                • 8741
                • Colin
                • Stafford, UK
                I've made one of these along with several of the masochists who frequent this forumGood luck! You will need it but I'm sure you will beat it.
                Steve, did you get a shiver down your back when you saw Romans next build ????
                Colin M...
                  Engine is finished... only must fix little gaps what you will see on pictures like No 1 and 2...
                  Besides wash and drybrush all I have doned freehand with AB. I have used alclad colors... iron, burn iron, hotmetal red and blue, pale burnt iron and dark aluminium... black is revell mat enamel.
                  I have drilled holes in the exhaust, and all other is OOB... dont know What else I can put on engine?
                  What is proper color of cockpit interior? Of course revell instruction sheet gave mix of 3 color... Last spit I have painted in Revell: 32167 Greenish Gray?
                  Roman
                    • 18266
                    Cock pit grey green... Xtracylx do the best match
                    Humbrol mid green #101 might work but will need lightening.
                    Vallejo model color: Gunship green#895 is close but to green, might need a bit of grey likewise their Green day#886 is to yellow and will need a touch of Green.
                    I went the easy way and ordered the Xtracrylix from John.
                    White ensign have it in their colour coat range but is out of stock. Their stocks are a bit erratic in the winter as the mixing is done in a cold and drafty shed and the guy that matches the paints is both old and in ill health.....
                      Thx Ian
                      Then I suppose this one is to dark?
                        • 18266
                        Sorry its hard to say on a pc screen. It looks a bit dark but as I say hard to tell for sure. I know nothing about Revell's paints.
                        • stona
                          • Jul 2008
                          • 9889
                          Here's the colour revealed by the removal of a data plate on an unrestored air frame.
                            hey vajled heres a photo of a spit cockpit in colour [ATTACH]40125.vB[/ATTACH] whether it helps or not im not
                            mobear
                            [ATTACH]43913.IPB[/ATTACH]
                              thx guys,
                              I think I'll have something very similar at home from paints...
                              Now I know witch tone of green is inside...
                              Thx again
                              Roman
