Your something is the throttle lever. The large black knurled wheel behind it is the elevator trim wheel and the smaller black wheel below it is the rudder trim wheel.Cheers
thx steve
you didnt understand my picture... Something is that part from stash... Some hidraulic thing... from what I made trottle lever
finally glued... catastrofic fit of parts into fuselage... you only must put your tounge in corner of the mouth, good aim and glu... and after that pray to all fit ok...
and now I will go to have double votka to calm mayself
Roman i hated putting cockpit in to fuselage i took 3 attempts dry fitting before i said to hell with it and glued then prayed hahahahaha,looks real good fit to me,i bow to your greatness
Well done Roman! Now you've got the challenge of the wing and those lovely wing fillets to look forward to. You thought the interior/fuselage fit was catastrophic :lol:
Well done Roman! Now you've got the challenge of the wing and those lovely wing fillets to look forward to. You thought the interior/fuselage fit was catastrophic :lol:Cheers
I have tryed dry fit of wings and fuselage... I dont see any problem at all... alo this part who present joint of wing and fuselage... with little effort it also came along very nice... unfortenutlly u cant see it right now because I ahve try that with my fingers...
And engine is up on dry fit
And now along with my Miss. Maniqure Magic sander :P I stolen from my wife new ones... and seems they are great...
After sanding fuselage joint I see I dont need for any drop of putty
I really dont know why the same model is different from person to person... I have same problems with my Revell RAFALE in 1/48. My friend was make it and no problems at all, but I had struggle with all possible joints...
I think is trick where are these models stored... maybe some source of heat deform plastic... how will know what is happening???
But I'm shure for one thing that you have nailed it pritty good
I have decide it that pilot dorr will be closed... but fit is terrible... to mutch gap on it... must do something there... how is your door fit?
