A Phantom for Halloween
  • Geoffers
    • Jan 2017
    • 1663
    • Geoff
    Hello Chaps,
    Well I’ve finished one GB and am about to wrap up my Mossie build so time for something new.
    What better for Halloween than a Phantom, in this case an Airfix 1/72 Phantom FG.1
    I’ve had this in the stash since last Christmas, it was a gift from my youngest son so thought it about time I built it.
    Pictures:
    The usual single bagful of sprues.
    Two nice schemes to choose from “Black Mike” of 111 squadron or a classic scheme from 43 squadron.
    And a few stencils to look forward to :astonished:
    I’m starting tonight once the trick or treaters have finished knocking the door so an update soon.
    Thanks for looking :thumb2:
    Geoff.
    • 18257
    Oh a spook. Nice one.
      • 18873
      Those stencils will drive you myopic at 1/72…….it will look great when finished though…..
      • adt70hk
        • Sep 2019
        • 10397
        Good luck with all those stencils!
        • Allen Dewire
          • 4741
          • Allen
          • Bamberg
          Looks a nice kit Geoff!!! As a kid, F-4's used to fly over my house, and I loved them too. Now a bit advice if I may...If the stencils start driving you bonkers, wrap the kit carefully and send it to Tony (yakface). He loves to stick 'em on and the more there are, the happier he is!!!...
          Allen
            • 22769
            Nice
              • 15630
              A great choice and these 1/72 Airfix kits are usually very good. As for those stencils - you have to question the sanity of that many at this scale :rolling:
                • 18257
                The are only about 300 stencil posts on a spook and weapons load out. Lol.
                • Geoffers
                  • Jan 2017
                  • 1663
                  • Geoff
                  Cheers Ian :thumb2:
                  Fingers crossed Tim :smiling3:
                  Allen
                  I’ll bear it in mind Allen :tears-of-joy:
                  Originally posted by papa 695
                  Nice
                  Hopefully Ian :smiling3:
                  I’m sure I’ll be questioning my own sanity Jim when it comes to applying them :tears-of-joy:
                  Should keep me out of trouble for a while or drive me crazy :tongue-out3: Ian.
                  Geoff.
                  • colin m
                    • 8727
                    • Colin
                    • Stafford, UK
                    I think I would be tempted to err, mislay a few really tiny decals.
                    • Geoffers
                      • Jan 2017
                      • 1663
                      • Geoff
                      :thumb2::tears-of-joy::tears-of-joy:
                      • Mickc1440
                        • 4775
                        Look forward to seeing this one come together, I once got to fly a Phantom simulator as a birthday present once.
                        • Geoffers
                          • Jan 2017
                          • 1663
                          • Geoff
                          Hello chaps,
                          Despite not posting any updates for a while I have been pottering away with the build.
                          Unsurprisingly the cockpit was first up which comes as a tub with various panels to be glued in, a few decals to pop into place before the seats are added.
                          So here is the cockpit all painted up using various Vallejo Model Air paints and a basic bit of weathering using Tamiya Panel line wash.
                          I’ve painted all the other internal bits and bobs such as intakes and engine parts so the next stage is to add the cockpit and join the fuselage together.
                          Hopefully another update soon, thanks for looking :thumb2:
                          Geoff.
                          • Geoffers
                            • Jan 2017
                            • 1663
                            • Geoff
                            Hello chaps,
                            Slow progress so far due to limited bench time but I’ve managed to get a bit more done.
                            With the cockpit finished it was time to bring the two fuselage halves together.
                            The spine comes as a separate piece which helps eliminate any nasty seam line down the centre.
                            The fit was generally good but I made sure I took time to glue it down a bit at a time.
                            The underside once gluing finished.Click image for larger version
                            The jet exhausts haven’t been fixed in place at this stage. The actual placement is a bit vague so I’m leaving them loose until the fuselage underside is fitted.
                            The aforementioned underside ready to be cemented into place.
                            A lot of the ancillary parts have been primed.
                            A bit more work to go but I’m really enjoying the build so far.
                            Geoff.
                            • Geoffers
                              • Jan 2017
                              • 1663
                              • Geoff
                              Hello chaps,
                              Seems like Halloween was a good time to start this build as so far it’s been a bit of a devil
                              The underside plate has been added but I really struggled to get it all to fit in place properly. I think it may have been slightly warped which meant lots of clamping to get it anything near a reasonable fit.
                              Unfortunately it seems that this has made the air intake covers trickery to fit. Some filler will be required despite some fettling.
                              I’ve also added the wing tip’s which come as separate parts. There is a bit of a step where it joins but I’m not sure if this is correct. I’ve looked at a few reference photos and checked out a couple of builds on YouTube but can’t find any reference to it
                              I’m putting this build on the back burner for a short time now while I start my Emergency Services Group Build entry.
                              Thanks for looking
                              Geoff.
