Hi, as the title says. I've paused my 1/32 Hasegawa Spit for a 1/72 Revell Spit. Commission build and surprisingly quite a detailed kit with interior so I've incorporated some of the detail from the Hase build into this one.
Here's the box and straight into the painting as the sprues are nearly similar to the Hase kit.
The destruction sheet is in full color...looks like most manufacturers are going this route.
The surface is finely engraved...
Fit is good.
Now for the interior...
The prop has to be assembled first and fitted before the fuselage halves can be mated.
Fit is good.
