That looks excellent, especially considering what wasn't in the box!
Revell 1:32 D.H. Sea Venom FAW 22
A bit more has been done.
Booms are on, fettling required, followed by the engine covers, again with a bit more fettling. No major surgery involved, just trial fit and sand to adjust.
chrisbComment
Continuing with the canopy, with the inside masked, on with the paint. Masking the inside didn’t take too long. I basically just followed the outside, if I went a little bit wrong, it didn’t matter.
Then these things. Wing strakes ? Or did I just make a word up? The kit item was way too chunky so a bit of sanding was required to make things acceptable.
Then, time to attach the outer wings.
These big plastic squares keep everything together, and do a nice job as well. Just a bit of fettling was required for a good joint.
These are wing fences. They serve to prevent airflow along the length of the wing, and thereby help prevent the plane from stalling.
A wing strake is a small surface that forms a (more or less) triangle between the fuselage and the front of the wing. Those serve to improve airflow or for better stabilisation.Comment
