Revell 1/72 B17-G Flying Fortress.
  • Valeron
    • Jan 2022
    • 944
    • Mike
    • St Albans
    #136
    Nice work Ron.
    I kike the effect of changing colour to show repaired panels. I've not come across that before.
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #137
      BRILLIANT MODDELING
      from the top shelf rifraf
      • stillp
        • 8096
        • Pete
        • Rugby
        #138
        It's not the neatness I have trouble with, but the smoothness. As usual, you've made it look easy!
        • minitnkr
          Charter Rabble member
          • 7550
          • Dayton, OH USA
          #139
          Beautiful work Ron. The straight pin trick I learned from MLHS guy back when good small decals were unavailable for 1/87 RR rolling stock & locos.
          • spanner570
            • 15428
            #140
            Thanks everyone. Very nice comments much appreciated. :thumb2:
            Mike, The idea just came out of my nut about the repaired panels as I was trying to figure out how to age the aircraft and make the thing look well used. I'm chuffed you like the end result.
            Quite right Paul. The pin trick decals work a treat for me and save an awful lot of unnecessary work and foul language. However, I do admire those who persevere with these tiny horrors, but it ain't for me.
            On with the painting.
            Remember to keep your paints thinned.
            Once I was happy what colour went where, I brushed on a second coat and started to tidy things up a bit in the process.
            Because I freehand my lines, I don't have to worry about leaving those little paint 'edges' sometimes left through using tape. As a result, I can go over the paint demarcation lines, and as long as I feather off the paint there are no ridges.
            I'm not after getting a shiny, factory fresh finish, 'cos I'll be weathering and mucking it up it to hell and back....
            See the scuff marks on the rudder? I don't know where they came from, and I'm not bothered how they got there, but somehow I've got me some unintentional flak damage!
            Also, seeing them has given me an idea........
            The above second coat will probably suffice. If I decide it will, I'll paint the black leading edges of the stabilizer and tail planes.
            Then give the area a last tidy up before adding the decals.
            Cheers all and thank you for your continued support and good humoured comments throughout this build.
            Ron
              • 15734
              Better and better Ron. Must take quite a leap of faith when you look at the first coat to know it will be OK. That first coat is an "Oh s**t, it's ruined" moment :smiling:
                • 22771
                #142
                Just caught up Ron, some outstanding work going on.
                • adt70hk
                  • Sep 2019
                  • 10419
                  #143
                  Yet again great work Ron!!
                  • Mini Me
                    • Jun 2018
                    • 10711
                    #144
                    Looks the bomb Mr. Ron :thumb2:
                    • spanner570
                      • 15428
                      #145
                      Thanks boys.
                      I've painted on the leading edges black and silver. Normally I would mark the lines with a pencil and work to these, but luckily, the leading edge panel lines were nice and distinct, so I was able to work the brush up to these to give me a straight line.
                      I've also added the butchered half cockpit and tidied things up as I went along and added a bit more weathering here an there.
                      Half cockpit frame fixed.
                      Ready for the decals. then I will add the wings. Finally fit the gun barrels and any other items that I might have otherwise knocked off!
                      Cheers.
                      Ron
                        • 22771
                        #146
                        Coming along great guns Ron.
                        • spanner570
                          • 15428
                          #147
                          Thanks Ian.
                          It's been a long, head scratching build, but hey ho, who needs an easy life? ME!
                          Thanks for the post.
                          Ron
                          • langy71
                            • 1950
                            • Chris
                            • Nottingham
                            #148
                            Thanks boys.
                            [ATTACH=CONFIG]n1191900[/ATTACH]
                            [ATTACH=CONFIG]n1191904[/ATTACH]
                            [ATTACH=CONFIG]n1191901[/ATTACH]
                            [ATTACH=CONFIG]n1191902[/ATTACH]
                            [ATTACH=CONFIG]n1191903[/ATTACH]
                            Cheers.
                            Ron
                            Love this,
                            I reckon that after this is finished we should all club together and buy you a full sized Tank to have a crack at....great work Ron..(as always)
                              • 15734
                              That is really looking the part Ron. I hope none of the decals are half over a bit you've chopped out!
                              • Mini Me
                                • Jun 2018
                                • 10711
                                #150
                                Easy remedy with a sharp blade or a pair of scissors......looking forward to seeing how you get on with it though.
