Revell 1/72 B17-G Flying Fortress.
Excellent comments boys. Thank you.
Here's the radio/navigation and flight engineer's area. I presume. :upside:
Totally fictitious dial colours, but they look pretty and do the job.
Like the front bit, rather late, I found a couple of minor scratch bits I could have, and will include, before the buttoning up is done.
Don't fret none boys. All the dust will be removed before I go around 'Touching Up' :flushed:....with me diddy brush.
Cheers.
RonComment
Thanks chaps.
The top and ball turrets.
The ball turret components. Observe the clear plastic 'Ball' which I've started to paint. What a ball ache to paint!
...and it still needs a heap of cleaning up.
The top turret framework was obviously a lot easier to brush on. The kit's clear plastic bits for the many and varied 'See through' frame details are very good. Well moulded with good grooves and raised frame work to follow with the brush.
In position.
Before I fit the ball turret, I have a bit of scratchery to do in that area.
Cheers all.
RonComment
That shouldn't bother Matron too much, Pete...She knows in a few days, it'll be time for Rons annual bath!!! Should cure the problem till 2024......BTW, nice work on the glass and the innards Ron.......
AllenLife's to short to be a sheep...Comment
Thanks for the usual abuse.
I would have it no other way!:smiling4:
I've made a start on the 'big' pieces of clear plastic. Complete with their usual bits of dust!
Thank goodness I only had one of these to paint.....
This little tinker goes above the radio shack and houses a .50 cal.
Cheers.
RonAttached FilesComment
On we go.
I don't know why the above image has decided to walk off the main thread pictures above and it's too late to edit, so.....
The tail gunner's turret and innards.
Again, a large area of clear plastic. As can be seen, I've painted some bits..
With the exception of the top turret, to prevent knocking off, all the .50 cal gun barrels are glued on almost last.
One side done...
Cut up, here's the second side which will be open. I only need the top bit.
Cheers.
RonComment
