Revell 1/72 B17-G Flying Fortress.
  • Lee Drennen
    • 7711
    #121
    Originally posted by Mini Me
    they never let you forget your act of transgression
    Sounds like a guilty party
    • Lee Drennen
      • 7711
      #122
      Looks awesome 570.
      • Mickc1440
        • 4786
        #123
        More great work Ron
        • adt70hk
          • Sep 2019
          • 10438
          #124
          Coming on very nicely Ron!!!
          • spanner570
            • 15482
            #125
            Thanks for the comments about the aircraft, chaps. :thumb2:
            I've started the painting. I've noticed that during their bombing campaign, the B-17's became well battered and bruised. I wondered how some even managed to fly.....
            As a result of seeing the images, I'm going to have me a bit of fun and try and make my model look a bit like them.
            I'm using Vallejo Air, thinned with tap water. All applied with either my favourite 'yard brush' (A cheapo wide flat headed one from the 'W***s', or a No.2 from those Airfix starter packs. Well used, but both have served me well over the years.....
            The first image shows a wing all squeaky clean after a brushed on coat of Vallejo Air Aloominum, red and an olive drab.
            It was at this stage I decided to 'Go Rough'
            Chris. Note the missing engine covers?!
            I first introduced some repair work to the wing's skins. For this I added a spot of grey to the aluminium and painted random panels.
            Then I painted over the whole surfaces with a much watered down aluminium and when the paint was tacky, I streaked the surface to follow the wind flow.
            Next, tidying up the demarkation lines, adding the decals and weathering.
            Cheers.
            Ron
            • spanner570
              • 15482
              #126
              Seems as though the thread is dragging on a bit, so I'll draw it to a close with seemly indecent haste.
              The nearly finished wings.
              I've brushed on a second and final coat of aluminium. Then went to work finishing them off.
              Port. Decals( the black lines were a sod to do as they kept breaking) and replacement panels added and I painted on some near miss flak burns to the paintwork by flicking paint at the wing surface.
              ....a bit of streaking to the underside. Most of the wing decals were far too small and couldn't be read anyway, so I used a trick taught to me by my late father. I used a safety pin dipped in black paint and 'Wrote' them myself. Near enough for me - Thanks Dad!
              Starboard. Same as above.
              Way too clean and smooth, me thinks
              The wheel looks wonky, but it ain't.:upside:
              I will add some more muck, wear and tear when they are glued to the fuselage.
              Next, I'll tackle the fuselage painting. Put it all together, touch up where required. :flushed: .....and then take a final look at the aircraft.
              Thanks for sticking with the build.
              Cheers.
              Ron
              • Allen Dewire
                • 4741
                • Allen
                • Bamberg
                #127
                It's a big WOW from me Ron!!! That is some great work going on here. Oh, and the pin trick also works well with a shaved down toothpick too. Nice!!!
                Allen
                  • 15799
                  Looking good Ron. Simple techniques to produce very realistic wear and tear.
                  Thread only drags because you've attracted all the site riff-raff who drift off subject into a discussion on missing clothes pegs and top shelf magazines :smiling:
                  • spanner570
                    • 15482
                    #129
                    Thanks Allen and Jim for for your nice and humorous posts.
                    Allen, good point, see wot I rote there? I found the trouble with a toothpick, is after a few 'Dabs' the point goes all soggy and blunt ( Insert smutty comments here) whereas a safety pin or similar, stays fine and sharp for weeks!
                    Jim, thank you. Very true about the thread.....
                    Thanks again for the input chaps. Much appreciated.
                    Ron
                    • Mark1
                      • Apr 2021
                      • 4156
                      #130
                      Coming together nicely :thumb2:
                      • adt70hk
                        • Sep 2019
                        • 10438
                        #131
                        Ron,
                        Yet again outstanding work. Simply first rate.
                        Can only imagine what you have planned for it!!
                        Very well done so far.
                        • outrunner
                          • Apr 2019
                          • 2420
                          #132
                          Lovely job Ron, well done.
                          Andy.
                          • Airborne01
                            • Mar 2021
                            • 4035
                            • Steve
                            • Essex
                            #133
                            That's a vast improvement (to my mind) Ron!
                              570 keep it going please, its most interesting.
                              453.
                              • spanner570
                                • 15482
                                #135
                                Thanks for all your encouraging posts, boys. :thumb2:
                                Time to paint the fuselage.
                                Because this particular B-17G was made up of two badly damaged aircraft, the original colours were left 'as was'. Hence my attraction to the thing in the first place.
                                I've made a start on one of the seven different colours in the arse end area of the aircraft.
                                As I only brush paint, I like to lay down the rough areas of the different colours first. Then I cut in a bit neater with each subsequent coat. This way, when working at speed, I know which is which, and my brush doesn't wander into the next colour - Too much. It usually does, but hey ho.
                                The main thing is to get the paint down quickly and smoothly. Neatness will hopefully come later.
                                First coat to figure what colour goes where.....
                                Don't worry if your brush wanders a bit. get the paint on smooth and flat.
                                Disgraceful, and mind yer winders!
                                Cheers.
                                Ron
