I have now decided to start to build a plane.
I choose the Me109 G2 from Orlik since it's an fairly easy aircraft to start with and the constructor is well known for his good fit.I hope you're not fed up with the Me's.....
I started with the cockpit as I have seen most builders do
Here I have put together the main cockpit construction
And started with the interior.....as you can see I added some dirt at the rear end
