Revell 1/72 FW190 -F8 with BV 246 Hagelkorn
  • yak face
    • Jun 2009
    • 13840
    • Tony
    Heres the Revell FW190 -F8 on the bench at last. Some may remember this was the kit I nicked the desert decals for the Airfix A-8 I did a while back . Its now getting done with the other decal option - an F8 with the experimental Blohm und Voss bv246 ‘Hagelkorn’ ( hailstone) glide bomb. This fascinating weapon featured a standard bomb but with added reinforced concrete wings and a basic guide system , theres an actual one at the RAF Cosford Museum . The aim was to release the bomb well out of harms way .
    Ive got an Eduard etched set but not sure how much of it is going to be useful as its not painted and a lot of the details are either too small or no improvement on the kit parts .
    On to the kit - its an older tooling from 1997 with the hagelkorn parts added a year later. As such its not bad ,featuring recessed panel lines and reasonable detail but the age of the moulds tells in areas of flash and excessive seam lines . As with the Airfix the kits designers have given you a tricky clean up with the nose ring sprue attachments , these encroaching right onto the front surface. Some other parts have excessive seams to clean up too like the delicate headrest assembly !Click image for larger version
ID:	1192250Click image for larger version
ID:	1192251Click image for larger version
ID:	1192252Click image for larger version
ID:	1192253Click image for larger version
ID:	1192254Click image for larger version
ID:	1192255Click image for larger version
  • yak face
    • Jun 2009
    • 13840
    • Tony
    I actually started this a week or so ago but didnt want to overload the opening post so heres a bit of progress. Ive got the cockpit painted up RLM 66 and been looking at the etched fret . I dont think im going to use much for the pit apart from the belts. The kits instrument panel isnt bad at all and has painted up nicely and the TINY etched rudder pedals are an impossible exercise in PE Origami and barely visible once fitted so they might not make the cut either! I mean threading the buckle on the foot straps !!? The whole thing is about 2mm in total!
    A major drawback on this kit is the clear parts . For one they arent the clearest , but the main gripe is that Revell have only supplied the glass part of the rear canopy , the sliding frame is moulded with the fuselage half meaning the only option is for a closed canopy and a messy clear part joint. Luckily the aforementioned Airfix A8 had two canopy options so the spare blown canopy from this is going to be used.
    This will involve cutting off the Revells canopy frame but this shouldnt be a problem . While im altering things ,the kits headrest is incorrect for a blown canopy F8 , it should have the added armour wrapped around it and slides back with the canopy so this will need sorting too. Click image for larger version
ID:	1192265Click image for larger version
ID:	1192266Click image for larger version
ID:	1192267Click image for larger version
ID:	1192268Click image for larger version
ID:	1192269Click image for larger version
ID:	1192270Click image for larger version
      • 15692
      Any thread with Hagelkorn in the title deserves looking into, if for no better reason than to find out what it means.
      You've given this a lot of thought and made a great start. The instrument panel looks really nice.
      • Neil Merryweather
        • Dec 2018
        • 5185
        • London
        Blimey!(in a good way)
        • Allen Dewire
          • 4741
          • Allen
          • Bamberg
          I'll try and keep up with this one Tony. Nice IP work. I can't blame you for not using much, if any, of the etch as it's tiny. At least Eduard had forethought with the name plate. Now you won't forget what you've built!!! BTW, what is part 4A on the sprue shot above???...
          Allen
          • yak face
            • Jun 2009
            • 13840
            • Tony
            Thats the armoured headrest and support allen , see what i mean about flash , seam lines and a couple of moulding pins to contend with?! Luckily this is one of the bits I’ll be altering when I sort the canopy.
              • 22770
              Nice start Tony.
              • yak face
                • Jun 2009
                • 13840
                • Tony
                Cockpit now done , i used the PE rudder pedals after all ( but didnt faff with the straps ) and the seat belts were a pain , tiny contact points for the shoulder harnesses and the lap belts had to be cut flush with the side of the seat or it wouldnt fit in the tub . Anyhoo its done and as can be seen ( or not ) most of it is hidden once the fuselage goes together. Before I glued the fuselage I had to sort the canopy issue. As said earlier , the Revell kit has the sliding section of the canopy moulded with the fuselage , not a great idea at the best of times but the clear section of the canopy was not very clear at all . Luckily the Airfix fw190 I did a bit back had two canopies , the unused one being correct for this aircraft. So the kit frame was razor sawed off and cleaned up . Click image for larger version
ID:	1193484Click image for larger version
ID:	1193485Click image for larger version
ID:	1193486Click image for larger version
ID:	1193487Click image for larger version
ID:	1193488Click image for larger version
ID:	1193489Click image for larger version
                • yak face
                  • Jun 2009
                  • 13840
                  • Tony
                  Started assembling the Hagelkorn , surprising how big it is ! Click image for larger version
                  • Allen Dewire
                    • 4741
                    • Allen
                    • Bamberg
                    Wow Tony, that is some good progress and luckily you had a clear piece to replace the canopy rear area. It's hard to believe you hacked off the old piece so cleanly too!!! You're really good at this 1/72 miniature madness wing thingy stuff...
                    Allen
                    • yak face
                      • Jun 2009
                      • 13840
                      • Tony
                      Engine cowling and nose ring now fitted and the one piece lower wing has been glued on . The lower rear fuselage joint needed a bit of filling as there was a step but no real problems. The wing tops however , when fitted with the locating pins , had a big gap . So off with the locating pins and glue the wing tight up to the fuselage, the slight misalignment caused at the wingtip will be easier to sort than filling a wingroot! Click image for larger version
ID:	1194203Click image for larger version
ID:	1194204Click image for larger version
ID:	1194205Click image for larger version
                      • adt70hk
                        • Sep 2019
                        • 10409
                        Coming on nicely Tony. Not be heard of the bomb thingamajiggy whatsitt before. Will follow with interest!
                        • yak face
                          • Jun 2009
                          • 13840
                          • Tony
                          All ready for a quick coat of Halfords grey , then not sure if im going to do a black base or not . Click image for larger version
                          • flyjoe180
                            • Jan 2012
                            • 12400
                            • Joe
                            • Earth
                            Looks good Tony. Looking forward to seeing the paint job
                            • adt70hk
                              • Sep 2019
                              • 10409
                              Originally posted by yak face
                              All ready for a quick coat of Halfords grey , then not sure if im going to do a black base or not . [ATTACH=CONFIG]n1194490[/ATTACH]
                              Got to love Halford's grey primer!!
                              Just a shame that half of it gets wasted.
                              Looking forward to seeing what you do with this.
                              ATB
