Revell 1/72 FW190 -F8 with BV 246 Hagelkorn
Daft question..... Never done it.......but is it as simple as spraying into the offending receptacle? What about cleaning the AB?
As I think you know, I currently only use water based products through the AB.
thanks!
Tony - apologies the slight detourComment
I decided to give it a coat of Halfords finest as I do find it helps everything else to stick better. Ive used the black primer before on bare plastic and found that it doesnt adhere as well as i’d like so I put it on top of the Halfords grey . Its now curing ready for the first colour to go on , RLM 76. The Hagelkorn bomb has also been sprayed - RLM 02 .Comment
Not wrong there colin , out of the whole PE fret I think only the belts and the rudder pedals were used - and I nearly didnt use the pedals ! The rest of it is either microscopic ,not needed for this version or no real improvement on the kit part ( instrument panel ) plus the flat nature of PE makes certain things look unrealistic . Dont get me wrong, its very useful most of the time but youve got to weigh up the pros and cons .Comment
Getting the top camo on ,starting with the rlm 75 and after a consultation with my personal Wurgermeister ( Alan G!) masked up with a hard edge for the rlm 74 . Once this has dried its time to unmask and then on with the mottle. [ATTACH]474993[/ATTACH][ATTACH]474994[/ATTACH][ATTACH]474995[/ATTACH][ATTACH]474996[/ATTACH][ATTACH]474997[/ATTACH]
Although somewhat surprised to discover Alan is a FW190 expert!:astonished:Comment
