Some great work going on here dude she is really looking the part.
Wingnut Wings 1/32 Halberstadt Cl.II (late)
What does not kill you, make you stronger, Allen.
Glad the damage wasn't irretrievable and that your coronary arteries withstood the shock.Comment
Greetings from the Halberstadt Aerodrome everyone,
Life goes on in the great war of nerves and progress must go forward, at all cost...First,
Oh Bro!!! This build will either make me or break me to pieces. Thanks Paul and the show must go on...
After decal-gate, I drove on and did (I hope) the last of the decals. There are little signs on the lower end of the wing struts, facing outwards. I laid out the struts in their order and put them on. Then brain fart #529 took over,
They are stenciled V, vorn or H, hinten (front or rear), and L and R. I studied the destructions for 30 minutes and laid them out in their respective positions. Applied the decals and then saw I screwed them up. The two on the left should have the decals on the other side. Too late to cry about it, so I hit them Set and Sol. I didn't want to risk trying to fix them...
I then decided to go ahead and mount the top wings. I had to use tweezers to pull down the rad pipe so I could get the wing in. The wing had a slot for the pin on the end of the pipe that fits into it. Ok, a bit more paint touchup on the pipe later. Wings glued on and time to see if the struts worked on the wings,
They aren't glued in place yet as this was just a test fit. They fit great and when glued, will be pretty stabile and withstand my rigging adventures (fingers & toes crossed),
A view from the top,
Happy with the results, it was time to finish the steering fin thing. I trimmed the pins and CA the 2 pieces together for strength against my rigging. I also don't like the standard fare of it being straight,
Just a test fit to ensure the pins fit into the fusi thang correctly. Another view,
I just hope the CA holds when I begin the string thing with 2 per side...
I am once again having probs with blue screens on the laptop and I'm not sure how long she will run this time. Thank you all for looking in and your great comments (and pics). You guys are the best!!!...Maybe more tomorrow?...
AllenLife's to short to be a sheep...Comment
This is looking soòo nice.
Seeing the paint job on the fuselage, I bet you could have done the wings as well.Comment
Hell's Bells Allen, you sure like living on the edge!! When I saw what you did to your B...1...R...D it even made my stomach turn.....just a little though. Good that you were able to save this beauty. Und now you Vill finish Der Flugzueg Machinen! :tongue-out3:Comment
