Academy 1/72 Cessna A-37B Dragonfly
  • flyjoe180
    • Jan 2012
    • 12400
    • Joe
    • Earth
    Academy's 1/72 Cessna A-37B Dragonfly. Has gone together quite quickly so far. I'm using Ammo acrylics, One Shot Primer, and Lucky vanishes. I won't put sprue shots up, you can find them online if you want to see what's inside.
    Here's the fuselage with 5 grams of nose weight and cockpit installed. I forgot to drill the holes for the refuelling nose probe and fuselage radome. Who needs hole guides anyway! Only a small amount of filler required:
    The exhaust area is pretty basic, just holes into trailing edges alongside a plate that gets attached to the sides. So I added some tubing to simulate pipes. They do not look this rough now:
  • flyjoe180
    • Jan 2012
    • 12400
    • Joe
    • Earth
    Fuselage to wing fit is good, some sanding and filling required particularly at the rear join.
    Ammo One Shot Black:
    The wire out each side is how I suspend it from a hobby vice while it is drying.
    Things slowed down as a tropical cyclone came through. I did get the underside colour on, and stores sorted:
ID:	1194402Click image for larger version
    • Steve Brodie
      • Sep 2014
      • 4652
      looking Nice
      • Geoffers
        • Jan 2017
        • 1700
        • Geoff
        Very nice :thumb2:
        Are the wires for lights?
        Geoff
          • 22770
          Nice work so far Joe, looking good.
          • flyjoe180
            • Jan 2012
            • 12400
            • Joe
            • Earth
            Originally posted by Geoffers
            Very nice :thumb2:
            Geoff
            Thanks Geoff; I threaded wire through the exhaust shield holes in the fuselage to hold it for paint drying. I'm not smart enough for electrickery :smiling3:
            • adt70hk
              • Sep 2019
              • 10409
              Cool!
              • JR
                • May 2015
                • 18273
                Very neat idea with that wire Joe .
                • colin m
                  • 8741
                  • Colin
                  • Stafford, UK
                  Looking good Joe. A nice looking aircraft the Dragonfly, with its low, squat, meaningful appearance.
                  • flyjoe180
                    • Jan 2012
                    • 12400
                    • Joe
                    • Earth
                    Thanks Colin. I've seen the A-37 at flying displays in South Vietnam Air Force colours, it's surprisingly quite a noisy and nimble aircraft with an impressive payload.
                    • flyjoe180
                      • Jan 2012
                      • 12400
                      • Joe
                      • Earth
                      USAF South East Asian scheme is on. I wanted the softer/messier edge to the colours and went for a light worn look using the black primer as a black base. Some clean ups to be done, but it will all darken under varnishes. I'm relatively new to acrylics, and previous experience with paint lifting under tape meant that I didn't spend any more than a few days getting the top scheme on. You have less trouble with paint lifting using enamels which are harder wearing but take a lot longer to dry. I have since painted the tail stripes, antennae, exhausts and exhaust shrouds, and the air to air refuelling probe. Landing gear and stores are ready. Updates to come.
                      • Mark1
                        • Apr 2021
                        • 4156
                        Looking good
                          • 18903
                          Looking very nice Joe.
                          • adt70hk
                            • Sep 2019
                            • 10409
                            Looking very good indeed!!
                            ATB.
                            • colin m
                              • 8741
                              • Colin
                              • Stafford, UK
                              That sounds like the perfect aircraft for an air show.
