Hasegawa 1/72 Beech T34 Mentor
  • yak face
    • Jun 2009
    • 13848
    • Tony
    Heres what i hope will be a quick build . Its the old Hasegawa beech mentor , dating from 1973 . Its a good little kit , quite detailed for its time with extemely finely done raised panel lines ( have to be careful I dont obliterate them with paint!) in 1970s silver plastic , even includes a display nameplate !
    it comes with 5 decal options for JASDF or USAF. It also comes with a little towing tractor ,which is nice.
    I made a start last night and its going together quite quickly .
ID:	1196076Click image for larger version
ID:	1196077Click image for larger version
ID:	1196078Click image for larger version
    • 22771
    Nice one Tony.
    • JayCee
      • Aug 2019
      • 1133
      The kit looks nice. The chocolate digestives even better. :smiling: .
      John.
      • adt70hk
        • Sep 2019
        • 10422
        John.
        Well spotted that man!!
        Something very different Tony!
        Good luck with the build.
        ATB.
        • yak face
          • Jun 2009
          • 13848
          • Tony
          John.
          Even better than that john - two chocolate hobnobs and two chocolate digestives ! ( well there was when i started , :smiling5: )
          • yak face
            • Jun 2009
            • 13848
            • Tony
            Got the interior done and fuselage together. I used painted strips of tape for the belts and just painted everything else. I painted some shapes on the fuselage sides , these will give the impression of detail under the closed canopy . I added two control columns from fuse wire as strangely the kit didnt supply any. Ive also started assembling the tractor , adding some plastic card bits to the wheelarches to prevent seeing all the way through . Click image for larger version
ID:	1196121Click image for larger version
ID:	1196122Click image for larger version
ID:	1196123Click image for larger version
ID:	1196124Click image for larger version
ID:	1196125Click image for larger version
ID:	1196126Click image for larger version
ID:	1196127Click image for larger version
ID:	1196128Click image for larger version
ID:	1196129Click image for larger version
ID:	1196130Click image for larger version
              • 22771
              Fantastic start Tony.
              • yak face
                • Jun 2009
                • 13848
                • Tony
                Bit more progress today until it just got too cold in the shed ( btw , had to dig a path to get in there , 12” of snow :fearful::tired
                The wings have been glued together and fitted to the fuselage along with the tailplanes , so its looking like an aircraft now. The canopy has been masked up ( my absolute favourite job :rolling and glued on , taped down until its cured . I think I’m going to go for option 1 on the schemes , the all over orange JASDF machine .Click image for larger version
ID:	1196341Click image for larger version
                • yak face
                  • Jun 2009
                  • 13848
                  • Tony
                  Airframe now in primer , next up - orange and as the instruction sheet says — everywhere!
                    • 22771
                    Coming along very nicely Tony.
                    • Allen Dewire
                      • 4741
                      • Allen
                      • Bamberg
                      Damn Tony!!! Slow down, will ya.......I can't keep up with all this stuff you keep building!!! It appears you need to find a job, or maybe a second one to give this old guy a chance to keep up Sir..........
                      Allen
                      • yak face
                        • Jun 2009
                        • 13848
                        • Tony
                        Allen
                        Cheers allen , you’re going to have to get the sunglasses out again once it gets painted
                        • flyjoe180
                          • Jan 2012
                          • 12433
                          • Joe
                          • Earth
                          Looking forward to the blinding scheme Tony
                          • yak face
                            • Jun 2009
                            • 13848
                            • Tony
                            After experimenting with the orange on a piece of primed scrap plastic its become apparent ( or should that be transparent!) that the grey isnt suitable for a base .
                            The orange paint ,once thinned for spraying , is quite see through so a coat of vallejo model color matt white has been applied which will give a much better final colour . I also gave the little tow truck a coat while i was at it , a few more bits to add to this yet and still not sure if im going to use the driver figure . Click image for larger version
ID:	1197385Click image for larger version
                            • Waspie
                              • Mar 2023
                              • 3488
                              • Doug
                              • Fraggle Rock
                              Looking good. (I must admit to liking your idea of seat straps! - I was wondering how I was going get round that one on my SK). Perks of being new!! Grab tips as you go along!!!
