Hasegawa 1/72 Beech T34 Mentor
  • yak face
    • Jun 2009
    • 13853
    • Tony
    #16
    First thin coat of orange and it looks like thisClick image for larger version
    Second coat and it looks like this Click image for larger version
ID:	1197443I think I need a final coat just to get full opacity . I might add a touch of white to the last orange coat , firstly to give it a bit more body and secondly as the orange paint tended to fade to a paler colour with exposure to sunlight .
      In that case, I think I would spray only the top with a lightened paint but use the full-strength one on the underside. Not that most would spot this difference, but it’s one of those “I know it’s there …” things
      • JR
        • May 2015
        • 18273
        #18
        How on earth you guys work in 1/72 and produce detail like that in the cock pit ! Well done .
        • yak face
          • Jun 2009
          • 13853
          • Tony
          #19
          Its now had a third and final coat , this time mixed with a bit of yellow and white to give it a bit more body and tone it down a bit . As jakko said I tried to go easy on the underside to simulate the fading effect of the sun . I also finished assembling the main body of the tractor and got some paint on it . Click image for larger version
ID:	1197503Click image for larger version
ID:	1197504Click image for larger version
ID:	1197505Click image for larger version
ID:	1197506Click image for larger version
            That’s going to draw attention
            • The Smythe Meister
              • Jan 2019
              • 6248
              #21
              ..... Shades on for this one!!
              ..... Looking good though.
              • yak face
                • Jun 2009
                • 13853
                • Tony
                #22
                • yak face
                  • Jun 2009
                  • 13853
                  • Tony
                  #23
                  Its now had a coat of Klear a few days ago and so decal time ! Or so I thought … first off I’ll start with the ‘ meatballs ‘ was my intention but on getting the decals out this is what i was faced with Click image for larger version
                  The white surround is way out of register making them look like googly eyes ! This is why some makers supply the middle spot of RAF roundels separately , the multiple printing of different colours can sometimes result in misalignment. Should be easy enough to make masks right ? No , as it happens my compass cutter only goes down to 10 mm diameter circles and the red part of the fuselage hinomaru is 8mm. So its mask and paint the white and either use a punch cutter to get the red bit of the decal , or use the punch cutter to make masks for the red bits . Either way here it is getting masked up for the white circles.Click image for larger version
                  • adt70hk
                    • Sep 2019
                    • 10428
                    #24
                    That's come a long way Tony. Love the orange! Roundels were bad! Never realised that's why the middles came separately.
                    ATB.
                    • flyjoe180
                      • Jan 2012
                      • 12433
                      • Joe
                      • Earth
                      #25
                      Nobody could ever say they never saw it coming. Looking great Tony
                      • yak face
                        • Jun 2009
                        • 13853
                        • Tony
                        #26
                        Got the white sprayed a few days ago so today time for the red bits . I planned to use decal for the red , punching it out of spare decals with an 8 mm hollow punch. This didnt go to plan as the edges of the punched circles were a bit rough plus the decals broke up on getting wet. So , plan B - mask up and spray the red . I used the hollow punch again , punching out 8 mm holes in Kabuki tape , stuck onto some shiny label backing paper.Click image for larger version
ID:	1198417Click image for larger version
ID:	1198418Click image for larger version
                        It was tricky to get the bang central but it worked out fine , except for the starboard stabiliser becoming a casualty. This has now been stuck back on and ive started with the rest of the decals. Ive got the matt black areas on the nose and behind the canopy to do next Click image for larger version
                        • Mark1
                          • Apr 2021
                          • 4156
                          #27
                          Shaping up very nicely.
                            • Jan 2019
                            • 6248
                            #28
                            Excellent stuff with the Red discs there Tony
                            This is going to be a cool build!
                            • Andy T
                              • Apr 2021
                              • 3239
                              #29
                              Great save on the red bits. I can well imagine that lining them up wasn't easy
                              • yak face
                                • Jun 2009
                                • 13853
                                • Tony
                                #30
                                Bit more done today . The wing walkway decals have been applied and the black anti glare sections round the canopy were masked and sprayed .Next up is a sealing coat of satin then its time for the undercarriage . Click image for larger version
