Papa 695s Airfix 1/72 Lightning
    • 22769
    Going to build this to go with the Salamander I’ve just finished, to make a small diorama.
    [ATTACH]476251[/ATTACH][ATTACH]476252[/ATTACH][ATTACH]476253[/ATTACH][ATTACH]476254[/ATTACH]
    • 18881
    That’s a great bird. I must make one someday…..
    • adt70hk
      • Sep 2019
      • 10400
      Now that is an iconic aircraft!
      • rickoshea52
        • Dec 2011
        • 4076
        • Rick
        Great kit. Take care with fitting the cockpit and intake trunking into the forward fuselage, I had to remove some material from the inside surface.
          • 22769
          Thanks for the heads up Rick.
            I had the same problem — see here for my solution (and a few posts down from there for the instrument panel, that also needs trimming).
              • 22769
              Finally made a start to this one. The cockpit fitted with no problem.
ID:	1231605Click image for larger version
ID:	1231606Click image for larger version
ID:	1231607Click image for larger version
                • 22769
                Going together very nicely.
ID:	1231647Click image for larger version
ID:	1231648Click image for larger version
ID:	1231649Click image for larger version
ID:	1231650Click image for larger version
ID:	1231651Click image for larger version
ID:	1231652Click image for larger version
                • Mark1
                  • Apr 2021
                  • 4156
                  Looking good, that took a while to get started,have trouble get the lid off the box lol
                  • Lee Drennen
                    • 7710
                    That is a nice looking kit Ian. Great updates I may have to try this kit sometime.
                    • boatman
                      • Nov 2018
                      • 14447
                      • christopher
                      • NORFOLK UK
                      well Ian i cant see you last lot of pics all iit shows are some tiny sqaures which is a pity on such a great aircraft
                      chrisb
                        • 22769
                        It is a nice kit Lee, I do recommend it.
                          • 22769
                          chrisb
                          They look ok on my end Chris.
                          • Lee Drennen
                            • 7710
                            Thanks Ian I may give it a go.
                            • boatman
                              • Nov 2018
                              • 14447
                              • christopher
                              • NORFOLK UK
                              SORRY Ian the pics now show must be my laptop duh
