Geoff’s - Revell 1/72 Lancaster B.III “Dambusters” tribute build
  • Geoffers
    • Jan 2017
    • 1762
    • Geoff
    Hello chaps,
    With my entry to Gerns Emergency Service Group Build finished I’ve got a bit of a gap before the next GB I’m entering starts in May.
    This year is the 80th anniversary of “Operation Chastise” more popularly known as the Dambusters raid.
    So what better than a tribute build of an aircraft that took part in the raid?
    I aim to finish it by the time of the anniversary 16/17th May.
    Not a lot of time to work with but if 617 squadron could be formed and trained for the operation in the slightly longer 21st March -16th May I’m sure I can manage it :smiling:
    I aim to build it pretty much straight from the box but may add a few improvements along the way depending on how it goes.
    I’m going to start after the weekend, all welcome to follow along :thumb2:
    Geoff.
    • 15818
    I've often been tempted with a Dambuster Lancaster so I'll follow along with interest.
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      I'LL Be followin Geoff seat at the front please before the rabble get their bums seated eh lol
      chrisb
      • Geoffers
        • Jan 2017
        • 1762
        • Geoff
        Glad to have you along Jim :thumb2:
        chrisb
        Pull up a chair Chris, you’ll get a better view from the front :smiling4:
        Geoff.
          • 18958
          Great subject Geoff. What marking options do you get? I know they will all be 617 squadron, just wondered which aircraft……
          • Geoffers
            • Jan 2017
            • 1762
            • Geoff
            Cheers Tim, it comes with x3 options:
            G- George - Wg.Cdr G Gibson
            P-Popsie - Flt lt H Martin
            F-Freddie - Flt Sgt K Brown
            Not sure which markings I’m going to use yet but I’m leaning towards F-Freddie.
            Geoff.
            • The Smythe Meister
              • Jan 2019
              • 6248
              Yep,
              I'll pull up a pew as well if you don't mind Geoff
                • 18958
                Geoff.
                Interesting that they never picked one that actually burst a dam :surprised: Freddie would be a good choice, it successfully attacked, but didn’t breach, the Sorpe simply because the upkeep mine wasn’t designed to destroy that type of dam construction. I always think of the Sorpe as the Cinderella of the dams. I bet 99% of these kits get built as G George though
                • adt70hk
                  • Sep 2019
                  • 10445
                  Hello chaps,
                  [ATTACH=CONFIG]n1197919[/ATTACH]
                  Geoff.
                  COOOOOOOOOOOOOOOOL!!
                  I was going to do this very kit for Jakko's TV/Movie GB but had to bow out due to my studies. Will bookmark for future reference
                  ATB.
                  • adt70hk
                    • Sep 2019
                    • 10445
                    Good point Tim about not having one that actually burst a dam! If I had done mine for Jakko's GB, I think I would have to have done G for George to fit in with the movie aspect.
                      • 18958
                      If I did this I’d probably go with that one as well, for pretty much the same reasons. That’s been one of my favourite films since I was a nipper……after all, if you don‘t hum the theme tune the whole time you are building it you must be dead……..
                      • Geoffers
                        • Jan 2017
                        • 1762
                        • Geoff
                        Yep,
                        I'll pull up a pew as well if you don't mind Geoff :smiling3:
                        Your very welcome Sir :smiling4:
                        Yes I thought G-George would be a bit obvious.
                        Perhaps Revell were a bit sensitive to put markings for an aircraft that breached the dams in view of the large loss of life :thinking:
                        I have some bomber command letters somewhere in the stash so may choose a different aircraft if they are suitable.
                        No need to him the theme tune I have it on CD so the neighbours are going tonne pretty fed up of it by the end of the build :tears-of-joy:
                        Geoff.
                        • adt70hk
                          • Sep 2019
                          • 10445
                          Geoff
                          I have a picture of model from Telford last year where someone recreated footage from one of the test drops (Les Munro's plane I think.) Would you mind me sharing the pics on here.....if only for some inspiration?
                          • Geoffers
                            • Jan 2017
                            • 1762
                            • Geoff
                            ATB.
                            Cheers Andrew, shame you didn’t get time to build it for the GB
                            Geoff.
                            • Geoffers
                              • Jan 2017
                              • 1762
                              • Geoff
                              Geoff
                              I have a picture of model from Telford last year where someone recreated footage from one of the test drops (Les Munroe's plane I think.) Would you mind me sharing the pics on here.....if only for some inspiration?
                              Feel free Andrew
                              I saw that, it was an awesome build :surprised:
                              Geoff.
