Airfix 1/72 Focke-Wulf Fw190A-8
  • Mickc1440
    • 4779
    With my Eagle finished and the decalling of my Dakota underway I needed another quickish build. This kit has had some mixed reviews but we’ll see. Oob with only swastikas added. It will be built wheels up on a stand.
  • scottie3158
    • 14221
    • Holbeach
    I'm in Mick.
    • adt70hk
      • Sep 2019
      • 10429
      Have this and it's sister kit in the stash...... Somewhere.... In fact i think you corrupted me into getting this one from Aldi or Lidl... :tongue-out3:
        • 15746
        I built this not long ago. It's a really nice kit. Typical of the Airfix new offerings. I also built it wheels up. I'm sure you'll make a great job of it and enjoy building it.
        • yak face
          • Jun 2009
          • 13855
          • Tony
          Great little kit mick , couple of points to watch out for are the nose ring sprue attachments - a tricky clean up , and the canopies are beautifully thin and clear but easy to crack when masking . Looking forward to the build cheers tony
          • Mickc1440
            • 4779
            I'm in Mick.
            Always a pleasure bud
            Who me? Never
            Thanks Jim
            Thanks for the heads up Tony
            • Valeron
              • Jan 2022
              • 944
              • Mike
              • St Albans
              I'm in. I have this kit in the stash so will be interested in seeing your build
              • Mickc1440
                • 4779
                Welcome along Mike
                The heads up on certain bits has been useful so far. Had a few fit issues but nothing a bit of patience and not rushing on too fast paid off so far. There are several bits of tidying up to do before undercoat.
                I’ve somehow lost the cockpit pic but now it’s buttoned up you can’t see anything.
                Bit of work to sort this but I was already aware there might be problems
                The wings went together nicely with just a bit of tidying up
                The buttoning up went really well especially the tail end. I’d seen a couple of builds where the two top panels at the front of the fuselage were problematic but apart from a bit of filler no hassles here.
                Using AM masks is fun in this scale but I made my own, the clear parts are as I was tolld, really nicely done which made this easier.
                Here’s where I am now. Some sanding and a few more parts to add.
                Thanks for looking.
                • adt70hk
                  • Sep 2019
                  • 10429
                  Looking good Mick. Fit issues duly noted for when I get around to my two and as you say not a lot see in the cockpit[it at 1/72, especially if the pilot is installed!!
                  ATB
                  Anderw
                  • Mickc1440
                    • 4779
                    ATB
                    Anderw
                    There certainly isn’t Andrew, glad I didn’t go for any AM stuff
                    • adt70hk
                      • Sep 2019
                      • 10429
                      Vey much agreed.....I've got a couple of Profipack 110s in the stash and so given the amount of glass I'm hoping that will allow you to see a lot more!
                        The one time I used pre-made masks I found them harder to apply than it was to stick tape to a canopy and cut it along the frame …
                        • Mickc1440
                          • 4779
                          Quite a tight cockpit this one, lots of glass in a 110
                          These frames are very fragile but the frames made it easy. I’ll definitely be using AM masks when I start my He111
                          • yak face
                            • Jun 2009
                            • 13855
                            • Tony
                            Quick work mick ! The cockpit is very small isnt it , not a lot can be seen apart from the seat . I spent ages painting the instrument panel on my revell fw190 and when its fitted you can‘t even see it!
                            • scottie3158
                              • 14221
                              • Holbeach
                              Mick,
                              Looking vert tidy mate.
