Airfix 1/72 Focke-Wulf Fw190A-8
  • Mickc1440
    • 4779
    #16
    Originally posted by yak face
    Quick work mick ! The cockpit is very small isnt it , not a lot can be seen apart from the seat . I spent ages painting the instrument panel on my revell fw190 and when its fitted you can‘t even see it!
    Definitely is small, the kit includes joystick and rudder peddles as well as two decals for the instruments, can only see the joystick
    Mick,
    Looking vert tidy mate.
    Thanks Scottie, I really need something bigger to work on
    • Mickc1440
      • 4779
      #17
      A bit more progress today, Brown 6 is now even greyer after undercoating
      • Mickc1440
        • 4779
        #18
        More progress today thanks to awful weather. First time using AK putty for masking and was impressed with the stuff.
        Carried on and got the decals on. Hopefully tomorrow I can seal it all in ready for weathering. Flying stand has also been assembled.
          • 15746
          Looking fine Mick. That masking putty is funny stuff but works well.
          • adt70hk
            • Sep 2019
            • 10433
            #20
            [ATTACH=CONFIG]n1198732[/ATTACH]
            [ATTACH=CONFIG]n1198733[/ATTACH]
            Looking good Mick and like the putty too.
            Keep up the good work.
            • Mickc1440
              • 4779
              #21
              Thanks Jim, it certainly is weird stuff when you first open the tin, I’ve only tried white tac before
              Thanks Andrew, clear coat on and drying
              • yak face
                • Jun 2009
                • 13855
                • Tony
                #22
                Lovely paintwork mick, cheers tony
                • Mickc1440
                  • 4779
                  #23
                  Thanks Tony, these things really are too small Just one 1/72 kit left for the Japanese GB
                  • Mickc1440
                    • 4779
                    #24
                    Brown 6 complete, not a bad little kit and a couple of new things tried during the build. I’ll take some more pics when it stops raining
                    • adt70hk
                      • Sep 2019
                      • 10433
                      #25
                      [ATTACH=CONFIG]n1198877[/ATTACH]
                      Turned out very nicely Mick.
                      Looks like you've got the same stands I have just bought... Displays the plane at a slight angle...up or down, depending on which way round you do it? How did you find them?
                      ATB.
                        • 15746
                        That's a great result Mick. It's a lovely kit. Stand sets it off well.
                        • scottie3158
                          • 14221
                          • Holbeach
                          #27
                          Mick a little cracker mate.
                          • yak face
                            • Jun 2009
                            • 13855
                            • Tony
                            #28
                            Cracking build mick , looks great in flight , cheers tony
                            • Waspie
                              • Mar 2023
                              • 3488
                              • Doug
                              • Fraggle Rock
                              #29
                              Grand build. Never seen that colour scheme before - looks fantastic.
                              • Mickc1440
                                • 4779
                                #30
                                ATB.
                                Thank you Andrew. The stand works really well but I had to modify the top where it connects to the aircraft. The block is way too big and would require a large hole in the underside. I removed the lug and added a pin instead
                                Thanks Jim
                                Thanks for that Scottie
                                Thanks Tony, its nice to build on wheels up
                                Thanks for that Doug, not a hard scheme to paint up. I do like it
