Airfix Supermarine Spitfire MkI/MkIIa
    Hey all, going to be working on this model soon, waiting on receiving a camera I ordered off amazon, So I will be able to take pictures of it soon.But I used a friends camera to take picture of the box and sprue, so here you go I am new to this and still learning so please be nice lol
    [ATTACH]40669.vB[/ATTACH][ATTACH]40670.vB[/ATTACH]
    ThanksScott
    [ATTACH]44341.IPB[/ATTACH]
    [ATTACH]44342.IPB[/ATTACH]
  • stona
    • Jul 2008
    • 9889
    Hi Scott,I've only got the dreaded red crosses in place of your pictures. It could just be me though.
      There you go, should be fixed now
      Scott
        great choice
        good luck in building...
        Roman
        • mossiepilot
          • Jul 2011
          • 2272
          Nice one Scott.
          I got the airfix spitfire and refueling vehicals diorama in the stash but waiting til I finished my 109.
          I'll be watching your build with interest.
          Tony.
            • 18272
            I might just be looking in on this one as I might be needing a 1/72 scale spit in the near future, so it will be good to see how this one looks.
              Look forward to seeing it come together
                • 22788
                Nice one Scott remember nice and steady if stuck ask away no one will bite on here and good luck with it
                  Looks nice, is this a re issue or a new tooling spit? Looking forward to see it started.
                  • stona
                    • Jul 2008
                    • 9889
                    Originally posted by \
                    There you go, should be fixed nowScott
                    Yes indeed,thanks
                      Good luck with this one Scott, you'll be ok with all the help from the aircraft guys on here!
                      Patrick
                      • colin m
                        • 8801
                        • Colin
                        • Stafford, UK
                        Daughter No 2 has the new tool (A01071A) Mk1a to build for a project at school. I've just had a look in the box and am very impressed by the standard of the kit. I suspect it will go together well. Good luck with yours.
                        Colin M
                          Hey guys here is a little progress since I have my new camera now, I am a bit disappointed with it though because picture is not clear :/ so sorry about that, I don't know if its the camera or if its because the cockpit is so small, but anyway here is the cockpit glued and ready to be painted Iv increased the resolution so I will try to get clearer photos next time, il see if increasing resolution helps, anyway I know its small progress but I hope you like it, I dont get much time to do atm because I have a 2 month old little princess to look after
                          [ATTACH]40788.vB[/ATTACH][ATTACH]40787.vB[/ATTACH][ATTACH]40786.vB[/ATTACH]
                          Scott
                          [ATTACH]44458.IPB[/ATTACH]
                          [ATTACH]44459.IPB[/ATTACH]
                          [ATTACH]44460.IPB[/ATTACH]
                            Hey guys here is a little progress since I have my new camera now, I am a bit disappointed with it though because picture is not clear :/ so sorry about that, I don't know if its the camera or if its because the cockpit is so small, but anyway here is the cockpit glued and ready to be painted Iv increased the resolution so I will try to get clearer photos next time, il see if increasing resolution helps, anyway I know its small progress but I hope you like it, I dont get much time to do atm because I have a 2 month old little princess to look after Scott
                            Scott I wonder if you are getting into close to your subject. All lens have a minimum distance form the object where they can focus. To close & you will be out of focus. Instructions should tell you.
                            If they do not take a series of pictures measuring the distance of each one. That will tell you if this is the problem. Also looks to me that you need some more illumination on the subject. Helps if you have a tripod as you will get a better picture with a longer exposure time. But you need the tripod to stop the normal shake of the body. If you do not have a tripod rest the camera on some books. Even make a sacffold out of sprue.
                              Try turning on the macro function Scott, that helps with close-up shots.
                              Patrick
