SMER FIAT Cr 32 Freccia in 1/48 ( ish!)
  • yak face
    • Jun 2009
    • 13840
    • Tony
    Seen as how ive nearly finished the Zero for Karls GB , a month early no less ! , I thought I could squeeze in a quickish build before Andys Japanese GB starts in july .
    This is the SMER reboxing of the old Artiplast tooling of the FIAT Cr32 . The kit is actually 1/50 scale but when SMER reboxed the Artiplast kits they marketed them as 1/48 . Its not a problem for me , i know it would drive some people mad though . Anyways its a 1960s tooling , so the detail in the cockpit is a seat ….thats it , just a seat ! But the external detail is quite nicely done and its got great decals ( I’m going to do the spanish civil war version ). Ive done one of these before , many moons ago** and got round the cockpit problem by sticking a pilot in - bugger all can be seen once hes installed , so i’ll be using that strategy again .
    **https://www.scale-models.co.uk/threa...34/#post-91630
    First off though , Ive got to fabricate a replacement tailplane and elevator as ones missing ! Click image for larger version
ID:	1202198Click image for larger version
ID:	1202199Click image for larger version
ID:	1202200Click image for larger version
ID:	1202201Click image for larger version
    • 15692
    Well Tony, you don't go for the easy option. A pretty basic kit with bits missing - right up your street :smiling:
    • yak face
      • Jun 2009
      • 13840
      • Tony
      You know me too well jim ! :smiling5:
      • yak face
        • Jun 2009
        • 13840
        • Tony
        Made a start on this. Ive drilled out the exhausts and cut a divider out of plastic card to stop the see through effect. I got a fat little mester out of the spares box to fill the opening nicely . The inside of the fuselage has been primed and will just be getting a coat of interior green. I was wrong about the kit only supplying a seat , theres an instrument panel too , so that doubles the parts count in the cockpit , yay ! Click image for larger version
ID:	1202234Click image for larger version
ID:	1202235Click image for larger version
ID:	1202236Click image for larger version
ID:	1202237Click image for larger version
        • adt70hk
          • Sep 2019
          • 10409
          Eduard it is not but looking forward to what you do with this!
          ATB
            • 15692
            Originally posted by yak face
            .... theres an instrument panel too
            They're spoiling you :smiling:
              The detail on the fuselage is not half-bad for a kit of this vintage, though. Recessed panel lines and rivets that are fairly fine, it could have been a lot worse.
              • yak face
                • Jun 2009
                • 13840
                • Tony
                Yes its quite nicely done jakko , a perfect mix of recessed panel lines and raised rivets ( although the rivets do look a tad big ! ) , it makes into a great looking model with a bit of fettling and a few refinements .( not to mention smoke and mirrors and just plain cheating - stick a pilot in to hide the lack of interior !) Cheers tony
                • yak face
                  • Jun 2009
                  • 13840
                  • Tony
                  The illusion has now started ! Click image for larger version
                  No its not Alice Cooper , I thought I’d try and help with defining his features so dry brushed white over the black primer . He’s now had a full face makeover and now looks a bit more human ! Click image for larger version
                  The fuselage has had the instrument panel added after painting a generic set of dials on it ( it wont really be seen as its quite deep under the coaming ) and the chubby Senor was tried for size.
                  This revealed that he was too low and couldnt see out of the cockpit ! So a booster cushion was installed under his square arse ! I also added a control column from stretched sprue as this would be visible between his legs . He’s now nestled in the cockpit and the fuselage halves have been glued , blocking all view of the total lack of interior . Next job sort the fuselage seams without losing any detail and fill those two whacking great sink marks on top of the nose !Click image for larger version
ID:	1202417Click image for larger version
ID:	1202418Click image for larger version
ID:	1202419Click image for larger version
ID:	1202420Click image for larger version
                    • 22770
                    Just seen this one Tony, a cracking start, and very nice work on the pilot. even though he looks like a child sat on a chair with his feet dangling.
                    • flyjoe180
                      • Jan 2012
                      • 12400
                      • Joe
                      • Earth
                      Nice start Tony. The face on you pilot is one of the best I have ever seen (not the KISS version).
                      • The Smythe Meister
                        • Jan 2019
                        • 6248
                        Originally posted by flyjoe180
                        .....The face on you pilot is one of the best I have ever seen
                        Couldn't agree more...
                        .... A superb job on him.
                        • Waspie
                          • Mar 2023
                          • 3488
                          • Doug
                          • Fraggle Rock
                          I flew with a pilot of similar stature so nothing amiss in my eyes!!!! :thumb2: :upside: :smiling3:
                          • yak face
                            • Jun 2009
                            • 13840
                            • Tony
                            Got the seams and sink marks filled and glued the lower wings on . I now turned my attention to the missing tailplane .two pieces of plastic card were cut to shape and glued together with a strip between them at the front edge for the elevator. The tailplane was cut from a piece out of the spares box . Click image for larger version
ID:	1202542Click image for larger version
ID:	1202543Click image for larger version
ID:	1202544Click image for larger version
                            I glued plastic strips for the ribs and decided to try and simulate the covered effect with microporous tape . I tried a bit and it looked good so both sides of the elevator were covered , cut to shape and given a coat of primer. Once this has dried it can be cleaned up and fitted . Click image for larger version
ID:	1202546Click image for larger version
ID:	1202547Click image for larger version
                              • 15692
                              Excellent work Tony. Pedro the pilot looks superb. Tail fabrication is really good.
