SMER FIAT Cr 32 Freccia in 1/48 ( ish!)
  • Neil Merryweather
    • Dec 2018
    • 5186
    • London
    #16
    Ooh very impressed,sir! I do like the microporous tape idea.
    • Geoffers
      • Jan 2017
      • 1700
      • Geoff
      Great stuff Tony, I’m enjoying watching you put this together :thumb2:
      I must say that it seems better to have limited cockpit detail to hide once buttoned up rather than spend age’s creating lots of detail that no one will ever see :thinking:
      Geoff
      • yak face
        • Jun 2009
        • 13840
        • Tony
        #18
        Progress has been a but slow lately , due to being busy at work and other things taking up spare time ( changing my car and laying some false grass !)
        Ive been cleaning up the fuselage and lower wings and now its in primer , with a few raised rivets reinstated with tiny blobs of canopy glue . The holes on the wings for the interplane struts dont line up with the struts fitted to the top wing ( i remembered this from the last one i built) so these were filled and re drilled . I also filled the holes for the machine guns as the kit supplied items were pants , plus I read that the wing guns were often removed to save weight .
        A lot of the kit parts either need replacing or extreme clean up like the square section , flash ridden cabane struts , these being sanded down to an aerofoil section . Other bits like the tailplane struts will simply be replaced with rod Click image for larger version
ID:	1203504Click image for larger version
ID:	1203505Click image for larger version
ID:	1203506Click image for larger version
ID:	1203507Click image for larger version
        Ive also assembled the wheel spats and cut out a section of the wheels so they can be fitted last off to save masking ( like The Smythe Meister , with his fascination for turrets , i’m very partial to a spatted wheel ! )
          • 18903
          Very cool. Excellent work that’s bringing this up to standard very quickly.
          • yak face
            • Jun 2009
            • 13840
            • Tony
            #20
            Forgot to say , I replaced the dodgy kit gun tubes with styrene tube , cut at an angle and flattened into an oval shape .Click image for larger version
ID:	1203625Click image for larger version
ID:	1203626Click image for larger version
ID:	1203627Click image for larger version
            Been looking at the pics on the walkaround and realised that the interplane struts have a collar type fixing at each end . Obviously the kit doesnt so I used curved strips of kabuki tape to wrap around the ends and secured them with a drop of superglue . I’m going to have to do something similar at the bottom ends and also on the N shaped cabane struts . Once this was done the underside of the top wing and the fuselage and lower wing got a coat of sky grey. That was yesterday so today the undersides got masked up and the top of the wing , fuselage and wheel spats got a coat of sand yellow . Next up is the green and brown mottles .Click image for larger version
ID:	1203629Click image for larger version
ID:	1203630Click image for larger version
ID:	1203631Click image for larger version
ID:	1203632Click image for larger version
ID:	1203633Click image for larger version
              • 15693
              You are really going to town with this Tony. Superb improvements.
              • flyjoe180
                • Jan 2012
                • 12400
                • Joe
                • Earth
                #22
                Looking good Tony, love the improvements
                  • 22770
                  #23
                  Great improvements Tony coming along very nicely.
                  • yak face
                    • Jun 2009
                    • 13840
                    • Tony
                    #24
                    Got the colours on now , next is a sealing coat of Klear so it is protected while the build carries on . Ive got the rudder to mask and spray white and I might mask and spray the various white and black stripes and circles rather than using the decals . Obviously some decals like the numerals and the roundel with the arrows on it will still be used .Click image for larger version
                    • Mickc1440
                      • 4775
                      #25
                      You're making a great job of this Tony, definitely a great improvement
                        • 18903
                        Looking good Tony. Camo has come out really well…..
                        • Neil Merryweather
                          • Dec 2018
                          • 5186
                          • London
                          #27
                          LOvely jubbly!
                          • The Smythe Meister
                            • Jan 2019
                            • 6248
                            #28
                            :thumb2:Gorgeous
                            • stillp
                              • 8093
                              • Pete
                              • Rugby
                              #29
                              Looking good Tony.
                                • 22770
                                #30
                                Great painting Tony, now go rest your eyes.
