Kotare Spitfire Mk.Ia (1/32)
Got back at 2.00 am Sunday morning (private charter to some godforsaken corner of Birmingham airport!) and have managed to get a bit more done.
Goodness me, it looks like a Spitfire.
This is the best fitting and engineered 1/32 Spitfire I have built, and I've built them all. The fit is incredible, I reckon the major components could be snapped together without glue; no idea why you'd do that, but you could. I've just reminded myself that those ailerons are just pushed into place and not secured by anything but friction.
You can't really give higher praise than that.Comment
Finally something I really don't like about this kit (just my opinion).
The decals!
There's nothing intrinsically wrong with them, they go on alright, but look at the code letters and roundel on this side:
That's all one decal, which might be okay at 1/72 but at this scale is ridiculous. With hindsight I should just have separated them, but success on this side led to overconfidence on the other side, resulting in a disaster, which brings me to another point. The colour of the codes looks way off to me. It should be Sea Grey Medium, but to my eye it's not close and is much, much too blue. This meant matching decals for the disaster was a real problem. I found a roundel in the spares, which was old and has 'shattered' a bit (I can fix that) but for the codes I had to cut up and make letters from the other decals in the kit... Not fun.
Also, the decals include things like detail for hinges and some stencils which is not a bad idea but is something I would normally do myself if I wanted to.
Next time I would simply use masks and spray these markings!Comment
The decals!
[ATTACH=CONFIG]n1204634[/ATTACH]
[ATTACH=CONFIG]n1204635[/ATTACH]
Finally finished the decals, at least all those I'm applying.
Kotare supply dozens of individual and miniscule decals for all the dzeus fasteners on the engine cowlings but they, for me, were a bridge too far. They are a very nice and unusual detail and I'm sure some would have fun applying them, but I can live without them :smiling3:
Next up some varnishing and weathering. This is this very aircraft shortly after P/O Richard Hardy was compelled to deliver it to the Germans at Cherbourg, having been damaged in an earlier action. There are quite a few images of this aircraft, the Germans seem to have been quite proud to have become the new owners and took several photographs.
Apart from some staining from the gun barrels and at the ejection ports there is a lot of oil under the nose coming, unsurprisingly, from the oil tank. It's not unusual to see oil here, but I wonder if this might be as a result of some damage or just hard flying. I won't be doing anything as extreme as this. Also notable is that when the new Sky underside colour was applied all those 'Location For Wingtip Steadying Trestle' and other stencils were over painted and not replaced. There are no under wing roundels either.Comment
I'm calling this one done!
Here's a brief history and some of my usual ham fisted photos:
