I have started work on the gun bay and nose section. It’s times like this that I am so glad I like to have the panels closed. Dry fitting shows that the gun bay and panels won’t fit at all so I have had to cut parts right back.
At least the panels themselves fit, as long as the internal detail is not there.
That’s a good starting point.
Here is the gun bay dry fitted to the nose.
I cut it back to this, still a dry fit and the main cannon is not in place as I will need to slide that in later.
I may have to trim more off later when I fit the nose.
The panels need some plastic sheet to make sure they have a strong join.
The central ‘spine’ could then be fitted, again it needed a bit of trimming with a bulkhead to the rear having to be cut off. That bit of bulkhead prevented the spine from fitting to the fuselage in the right position.
I am leaving that to properly dry before the next stage
