1/72 Revell Hurricane
  • stillp
    • 8093
    • Pete
    • Rugby
    Well, my Stuka is finished (unless I decide to give it a dust wash!) and I have a Zero waiting for the start of the Japanese Aircraft GB, so I need something quick to fill in the rest of this month. I picked up this Hurricane at an autojumble for £1 a couple of weeks ago, and it only has about 18Click image for larger version
ID:	1203318 parts, so it shouldn't take long!
    No box, but the instructions and decals are there:
    The tooling seems to date from 1962, and there are places where that shows - including the pilot, who looks like the monster from the black lagoon, in a sleeping bag.
    Surprisingly, he's quite detailed, but that's largely hidden by the mould misalignment and flash. Apart from him/her/it, there's no other cockpit detail. I suppose I'll have to stick something black in the front of the cockpit for an IP.
    The fuselage halves seem to fit together quite well but there are some horrible sink marks on the underside.
ID:	1203320Click image for larger version
    I think I'm going to brush paint this kit, something I haven't done since I discovered acrylics... what could possibly go wrong?
    Make it a nostalgia build: put it together like you would have done in your youth, just with better technical skills: straight from the box, no additions, just clean up the parts and put them together per the instructions. With tube cement, of course, and use the exact paints that the instructions recommend — enamels rather than acrylics, if at all possible. If you don’t have a colour, take the one you do have that you think is closest without doing any actual research, and regardless of whether it’s matt or gloss
    • stillp
      • 8093
      • Pete
      • Rugby
      Do I have to leave a glue thumbprint on the canopy Jakko?
        • 15692
        Oh that looks horrible. You paid £1 - I think you were done :rolling:
        It will be interesting to see what you can do with it.
        • adt70hk
          • Sep 2019
          • 10409
          To be honest if have to be paid to take that kit!!!
          • stillp
            • 8093
            • Pete
            • Rugby
            Here's the instructions and paint colours:
ID:	1203324Click image for larger version
ID:	1203325Click image for larger version
            The highlighting was there when I bought it.
            I don't have any Revell enamels, but I do have most if not all of those colours in Revell acrylics so I might stick to those as far as I can. You might notice that they've forgotten the key for some of the colours. (Sorry about the blurryness, my modelling camera is sulking).
            • stillp
              • 8093
              • Pete
              • Rugby
              Oh come on you two, where's your sense of adventure? :tongue-out:
              • Neil Merryweather
                • Dec 2018
                • 5185
                • London
                They're just snobs, Pete :rolling: don't take any notice of them
                  This is marked as optional, left to personal preference. A big blob of tube glue left somewhere like on a wing is an acceptable alternative.
                  • Andy T
                    • Apr 2021
                    • 3239
                    You're a brave man tackling that Pete. Best of British!
                      • 18903
                      I expect Mig do a decal for the thumbprint somewhere……
                      Good luck with it though.
                      • Waspie
                        • Mar 2023
                        • 3488
                        • Doug
                        • Fraggle Rock
                        Well, my Stuka is finished (unless I decide to give it a dust wash!) and I have a Zero waiting for the start of the Japanese Aircraft GB, so I need something quick to fill in the rest of this month. I picked up this Hurricane at an autojumble for £1 a couple of weeks ago, and it only has about 18[ATTACH=CONFIG]n1203318[/ATTACH] parts, so it shouldn't take long!
                        [ATTACH=CONFIG]n1203317[/ATTACH]
                        [ATTACH=CONFIG]n1203319[/ATTACH]
                        [ATTACH=CONFIG]n1203320[/ATTACH][ATTACH=CONFIG]n1203321[/ATTACH]
                        That’s how I remember kits from my youf!!! You can see why they ended up air rifle fodder!! (Targets) :thumb2: :smiling3: :smiling3:
                          • 22770
                          Nice to see an old kit getting built Pete, I'm sure you'll knock it into some kind of shape, but not sure about the pilot thing.
                          • stillp
                            • 8093
                            • Pete
                            • Rugby
                            Fuselage together. I had to stick a bit of plastic in for the IP, and another behind the lagoon monster's head. I drew the line at cockpit sides though! The LM/pilot is supported by pins on the cockpit sided that go into holes in his shoulders - one fitted, the other is too short. Well, he's not going anywhere.Click image for larger version
ID:	1203525Click image for larger version
                            At this point I realised I'd mad a mistake - the prop is supposed to fit into a collar and be inserted between the fuselage halves before they're joined. I'm not bothered about the prop being able to spin so I'll just glue it on afterwards.
                            On to the wings:
ID:	1203527Click image for larger version
                            Pretty good fit. Not perfect, but a smear of PPP will sort that out.
                            Not so good underneath though:
                            As well as the wing being a bit smaller then the gap in the fuselage, there's a massive step in the rear fuselage, seen here with a grey layer of Humbrol filler. Revell have kindly moulded the kit's production date of 1962 into the lower wing, along with a slot that I suspect is for a stand. That'll get filled as well. I might leave the date on though, for any future viewer who wonder why this model is so crude!
                            Have to love those lines of rivets, that run completely around the engine cowl!
                            • stillp
                              • 8093
                              • Pete
                              • Rugby
                              I tried a bit of brush painting but wasn't happy with the results, so it's back to the airbrush. The black/white underside has been done, and I decided to airbrush the camo freehand, with a few pencil marks to help. Using and oldish set of Hataka paints. Unplugged the compressor so I could plug in my Whirlimixer to give the paint a really good mix. Filled the a/b cup with thinned paint, pressed the trigger, and blew paint out of the cup all over the inside of the spray booth! Tightened the nozzle cap and cleaned up a bit. Started spraying OK, then had some tip dry. Cleaned the tip, added a little more thinners, sprayed a bit more, a bit spattery but then the paint stopped coming out. Cleaned the tip again, turned up the air and the paint, sprayed a bit more, then - nothing. No paint, not even any air. Took the nozzle and needle out, full of paint but no apparent blockage. Tried to spray IPA - still nothing. The I reslised - I'd unplugged the compressor so I could power up the vortex mixer, but forgot to plug it back in! :rolling: Note to self - compressors work best when powered.
                              All was well with the compressor running, so finished the Dark Green:
                              I'll get the Dark Earth on later. Might try brushing that so I get a sharp transition between the colours.
