Hachette Build the red barons fokker dr1 1/8 scale.
  • peterairfix
    • Jul 2012
    • 11075
    Where do I start first of all this magazine part work came out in 2004 I have had a stab at this before but my skills weren't that good.
    I brought a complete unstarted set witch is most unusual and you could say rare
    Some pictures of whats I store.Click image for larger version
ID:	1203708Click image for larger version
ID:	1203709Click image for larger version
ID:	1203710Click image for larger version
ID:	1203711Click image for larger version
    • 22770
    Looks like lots of work Peter, but should look stunning when completed.
    Are you going to try and put fabric on it?
    • peterairfix
      • Jul 2012
      • 11075
      The last time I tried I made a complete #&&&#@# up but as I have more skills I am definitely going to have a go
        • 15693
        Looks very interesting Peter
        • Waspie
          • Mar 2023
          • 3488
          • Doug
          • Fraggle Rock
          I used to love building balsa kit planes. And that looks a cracking model to build indeed.
          My balsa aircraft building came to an abrupt end when all my five aircraft I had spent years constructing were converted to matchwood by an Ayr based removal company!! Ever since - just never had the inkling.
          Only ever flew them once to prove they worked, then stored. To me, the skill and pleasure was in the building!!
          Really look forward to watching this come together.
          • outrunner
            • Apr 2019
            • 2420
            As another who used to build and fly balsa (and foam) model aircraft it should be OK to build but will take a bit of time. If you cover it with Solartex it will give the real fabric look but left open it would also look good and any onlookers could see the work you put in.
            Andy.
            • peterairfix
              • Jul 2012
              • 11075
              Part one finished this part fits between the wheels. Click image for larger version
ID:	1203805Click image for larger version
              • scottie3158
                • 14201
                • Holbeach
                That should keep you out of mischief for a while, I will follow along if you don't mind.
                • peterairfix
                  • Jul 2012
                  • 11075
                  Pull up a chair
                  • peterairfix
                    • Jul 2012
                    • 11075
                    I will say two wing sections completed but knowing part works there will something later for them Click image for larger version
                    • Mickc1440
                      • 4775
                      I’ll follow along too Peter
                        • 18269
                        You are on a roll dude.
                        What are you going to build next week lol.
                        That looks an impressive kit that. What's the wingspan like?
                        • peterairfix
                          • Jul 2012
                          • 11075
                          I am about to join the two halves together so I will put some pictures up tomorrow
                          • stillp
                            • 8093
                            • Pete
                            • Rugby
                            Should be just under 900 mm.
                            • peterairfix
                              • Jul 2012
                              • 11075
                              I forgot to add I made up one of machine guns Click image for larger version
ID:	1203881Click image for larger version
ID:	1203882Click image for larger version
ID:	1203883Click image for larger version
ID:	1203884Click image for larger version
ID:	1203885Click image for larger version
