The first 50 cal brass gun barrel glued in place with ca.
I have some tricky painting to do inside the transparency. This is also the rear turret so it has that horrible join. This is the worse thing about this kit and I will just have to make the most of it. At least with the D it’s only the one turret, the J has this issue on both. I am not sure how I will glue this yet, probably not plastic cement, Gator Grip is an option but the non-fogging ca might be better. I also have a clear two part epoxy to consider.
