P-51D "Petie" 1:33 Halinski
    One of the landing gears is mostly done.
    Rather slow progress at the time,but outdoor activities and not much time to build due to other tasks is the reason
      nicely done Johnny!
      im going to start that 1/32 F-15 today, just need to find the folder i put it all in lol.
        Lousy weather....fall season invites me to continue the P51.
        The wings are made
        • jspitza
          • Jul 2007
          • 586
          #34
          Outstanding work, Johnny! I just have too many plastic (and one wood) kits to finish so until I'm old, cranky and grey I probably won't start a card model. Oh, who I'm kiddin! :noidea:
            Let me give you some good advice then
            If you have plans of finishing your models......don't start to build a papermodel......
            It's like drugs I guess......one cut and you're hooked
            • jspitza
              • Jul 2007
              • 586
              #36
              Originally posted by \
              Let me give you some good advice then If you have plans of finishing your models......don't start to build a papermodel......
              I already have a mental problem and I'm seeking help through IPMS. I wonder if there is a ICMS? Get it??? International Card Modelers Society. :lame:
                Exhaustpipes and the wing guns
                  Hi Johny,I'm loooking for a 1/8th scale pilot, do you think they will have one of them or do you know where i can get one from its for next project a P47D Thunderbolt from topflite.
                    This is unbelievable Johnny - I can't believe this is all card!!! You are indeed a magician sir!
                    Stuart
                      Continued work on the plane today. I'm home with some broken ribs....and today the pain was manageable.I had a crash on my bicycle and the tarmack is very hard when you hit it at 35km/hr....
                      But onto the build!!
                      Details on the landing gear.The part is the one at the tip of the Exel #11 blade.6 of that part was to be small hinges at the compression cylinder at the legs.
                      Landing gear done.
                      Front and rear side
                      Canopy is done.
                      I also started to do the fairings (was that the correct name?) And the guns are done on both side. Did I overdoe the gunsmoke leftover sliding along in the wind effect??
                      Hepp hepp!!
                        That's strange Johnny, none of these pictures seem to open up to normal size, have you done anything different with them?
                        I know what you mean about the gunsmoke effect I think it should be a lot softer by either airbrushing or careful build up with dry brushing. I don't know what you can do with what you have there to soften it without causing any damage. You might have to live with it.
                          I haven't done anything different than before,so I don't understand why they won't open to normal size.
                          I'll tone the slag down to just a shade I think.
                          That's strange Johnny, none of these pictures seem to open up to normal size, have you done anything different with them?I know what you mean about the gunsmoke effect I think it should be a lot softer by either airbrushing or careful build up with dry brushing. I don't know what you can do with what you have there to soften it without causing any damage. You might have to live with it.
                            The fairings
                            Got the fairings done today
                            Now I can see the end of this build getting a bit closer.When the wings are done....only the rest left!
                              Another part done
                                So there was the day that the "petie" should up on her wheels.
                                The rear wheel
                                The landing gear and one of the wheelwells covers are in place.
                                Also the typical air inlet and the two hatches on the rear part.
                                Seen from Down under
