Pete's Black Arrow
    • 18890
    Hi Pete. I use Galleria matt on the little blokes. Brushes OK on them, but not sure about such a large flat areas. It may be a bit thick to get a level even coating. If you’ve ever used anything from the Humbrol (Matt) cote varnish range it is very similar.
    • Mickc1440
      • 4775
      #32
      Looks really nice
        • 15653
        I know it must be driving you mad but it actually looks good. You're right in that the black coat has pulled it all together. Canopy looks fine. Not that far to go now.
        • stillp
          • 8087
          • Pete
          • Rugby
          #34
          Thanks Tim. Do you thin it at all? I've never used the Humbrol matt cote.
          • boatman
            • Nov 2018
            • 14451
            • christopher
            • NORFOLK UK
            #35
            Pete dont bin it please as for me this brings back child hood memerioes as i built one of these back when i was about 10 yrs old an yours is lookin good so stick at it
            chrisb
              • 18890
              I use it straight out of the bottle Pete. But as I said, I’m using it on figures so don’t worry if it isn’t dead smooth. Not sure what you’d thin it with to be honest. It isn’t cellulose or enamel based.
              • Allen Dewire
                • 4741
                • Allen
                • Bamberg
                #37
                Mr. Ketchup here, Pete...This build has really shown your true determination and mule headedness (stubborn) to keep going. I know you are not one to bin an expensive kit and you are almost to the finish line Sir!!! Keep on truckin' and I do hope you are feeling much better now too!
                Allen
                • Andy T
                  • Apr 2021
                  • 3239
                  #38
                  I've thinned Galleria matt & gloss with a little water before now to put it through the airbrush, so I should imagine the same would work for brushing if you find it necessary.
                  • stillp
                    • 8087
                    • Pete
                    • Rugby
                    #39
                    chrisb
                    Chris, it'll go in the bin, but I'll finish it first and post a couple of photos, but don't expect a good model.
                    I don't display my finished models, and this one isn't good enough for ebay. Might just keep it as a paint mule.
                    • stillp
                      • 8087
                      • Pete
                      • Rugby
                      #40
                      Oh dear. For some reason that I've forgotten, I left the main gear wheels off, probably to save masking them. Just fitted them and only now realised why there are two locating points in the semicircular part of the bay doors - the wheels don't reach the ground, but the bay door does!
                      The nearer (port) wheel looks OK in that photo, but it isn't, they're both the same. I think both my brain cells must have been having a holiday when I fitted the landing gear legs. Actually I think the way I have it is the only way the legs and the straight part of the door would fit.
                      Oh well, at least the decals went on alright. I'd given them a coat of Microscale Liquid Decal Film in deference to their age. I small part of one of the fuselage roundels did break off but i managed to coax it back into place.
                      In other new, I tried brushing some Galeria varnish on an old kit, and it seems to brush OK straight from the jar, so when the decals have dried fully I'll give the 'plane a clear coat. The see if I can rescue the undercarriage somehow.
                      • stillp
                        • 8087
                        • Pete
                        • Rugby
                        #41
                        I should have researched more carefully. The instructions seem to suggest that both parts of the U/C doors are attached to the U/C leg, but only the curved part is - the mostly rectangular bit is angled outwards, and overlaps the curvy bit.
ID:	1213231Click image for larger version
                        Second photo is mine, taken at Sywell.
                        More work to do!
                        • stillp
                          • 8087
                          • Pete
                          • Rugby
                          #42
                          That's better:
                          Second coat of Galeria drying at the moment. I'll take a couple more photos later before it goes in the bin.
                          • Allen Dewire
                            • 4741
                            • Allen
                            • Bamberg
                            #43
                            Well Pete, after all the effort and hard work you put into this expensive kit, I wouldn't bin it! You could use it for.......Umm......Uhh....Maybe....Ahh.......A new hood ornament on your Trumpy!!!...Yea, that's a good idea Sir!!!
                            Allen
                            • stillp
                              • 8087
                              • Pete
                              • Rugby
                              #44
                              Oh well, this isn't going to get any better so I'm calling it finished.
                              Not an enjoyable kit to build, but I could/should have built it a lot better.
                              More photos in the Finished section.
                              • boatman
                                • Nov 2018
                                • 14451
                                • christopher
                                • NORFOLK UK
                                #45
                                [ATTACH=CONFIG]n1213522[/ATTACH]
                                LOOKS GOOD too me Pete better than my effort of 60 yrs ago
                                chrisb
