1/72 Hasegawa Lancaster
Tags: None
I have just done part of the bomb bay but instead of replacing original floor of the aircraft I have amalgamated the two to tmuse the original as a guide.Comment
Well bomb bay in and interior all sprayed black (just undercoat currently).
Plenty of cutting but generally the dry fit all seems good without any real force or modification required.
Unfortunately the resin bomb racks are so fine they seem to just snap as soon as I try any form of removal even with a fine scalpel so looks like any bombs will be fixed using the original kit parts.
As an aside I really like the way the wings fit, the two prongs fit snuggly into the wing and then the whole wing fits into a recess, it's a great piece of design!Comment
F14 finally done, continue with Lancaster now!
Eduard detail set is great and very appropriate as only detailed areas are ones that can actually be seen through the canopy.
The bit hanging down on the left bottom side of the main pilots control panel is godly as this is a folded (three folds) platform and would be extremely difficult without a folding jig. It measures about 2mm square when complete.
Inside black and green done, need to weather green and give it some depth/contrast.
