1/72 Hasegawa Lancaster
  • adt70hk
    • Sep 2019
    • 10438
    #16
    Coming on very nicely! Although I'm sorry to hear about the bomb racks too.
    Yours
    • Ancientmariner
      • Feb 2018
      • 859
      #17
      I am pondering them currently. Will post photo later, they are a pig and so fragile!!
        • 22788
        #18
        Just seen this one James, very nice work so far.
        • Mini Me
          • Jun 2018
          • 10711
          #19
          Glad you're back at it James.......model on!
          • Ancientmariner
            • Feb 2018
            • 859
            #20
            Fuselage together, not yet sanded joins.
            Decided today to tackle a wing and to do wheel bay and flaps/ailerons at the same time to simplify.
            Wheel bays the resin additions add a bit but not masses. The flap parts do look good though. One wing took about 3 hours.
            Resin extras for wings/tail and wheel wells.
            Wing pre cutting and post cutting.
            Finally detailed wing compared to factory wing.
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #21
              LOOKIN VERY GOOD James very well done my freind
              chrisb
              • Ancientmariner
                • Feb 2018
                • 859
                #22
                Fuselage together, undercoated, filled gaps, undercoated and painted wheel bays and flaps (I did these green instead of black just to add some colour more than anything). Think once gloss varnished they should come up well with a dirty brown wash.
                Not sure on whether to pre shade as it's only 1/72 panels are small and close together.
ID:	1215483Click image for larger version
ID:	1215484Click image for larger version
ID:	1215485Click image for larger version
                  • 22788
                  #23
                  Looking very good, nice work so far James.
                  • Mini Me
                    • Jun 2018
                    • 10711
                    #24
                    Pre shade might be worth a go....not tried it in 1-87 yet but might consider it for my next wingy build
                    • Ancientmariner
                      • Feb 2018
                      • 859
                      #25
                      Had a few spare minutes, top almost preshaded, got to mask flaps and wheel bays before doing underneath.
                      • Waspie
                        • Mar 2023
                        • 3488
                        #26
                        Very nice James.
                        Question I have wanted to ask for a while! When pre-shading do you use an airbrush? Or hairy stick?
                        • Ancientmariner
                          • Feb 2018
                          • 859
                          #27
                          Originally posted by Waspie
                          Very nice James.
                          I use an airbrush as you get the fade as you work out from the line if that makes sense which you don't with a hairy stick. Was a bit trial and error that as it is quite a small kit compared to what I'd usually pre shade.
                          • Mini Me
                            • Jun 2018
                            • 10711
                            #28
                            It will be worth it if it works out in the smaller scale though.....standing by for further developments.
                            • Ancientmariner
                              • Feb 2018
                              • 859
                              #29
                              So the pre shade came out ok (though it doesn't show in pics because the lighting isn't that good).
                              Main three colours done and a coat of Mr Colour GX clear super gloss applied and drying ready for the decals. Wheels, under carriage doors, turrets and bomb bay door etc all to be added soon.
ID:	1216297Click image for larger version
                                • 15798
                                Looking very good James. Some resin parts are so fragile that clean up is virtually impossible. Glad the control flaps etc all fitted fine as I notice they were for the Tamiya kit. That's a very competent pre-shade.and paint job. You're making a cracking job of this lesser known Lancaster kit.
