So played about a bit more today. Fitting wiring etc isn't the easiest as I am only using stuff I have as I'm making a point of buying anything that isnt essential and all my connecting wire is 2.5mm core i had left iver from the shed.
The plinth has made life a lot easier as opposed to routing channels for wires. There will be a 9V battery and switch mounted outside and actually with all the LEDs onto it it means they are a little dimmer which I like as it's a smaller kit.
Also managed to get it primer today which I am pleased with. Couple of hours with an airbrush and it will be done.
