Boatmans Super Tomcat F14D Build
    • 15653
    Great job with the channel cutting Chris. You have great skill and patience. Adding the electrics is a huge amount of work.
    • boatman
      • Nov 2018
      • 14451
      • christopher
      • NORFOLK UK
      #182
      HI Jim yes i was a nervous wreck after doin that channell cutting as just one slip of the dremel an i could have gone right through the wings or tails veticals so had to concentrate really hard but it was a releif to have done it as they would not have fitted togeather otherwise an it took a fair while to do but by doin a small bit at a time i got there in the end but like all modelin it just a matter of patience an enjoy the modeling but still more leds to fit in her so got to think ahead if possible as ive got to fit all these wires togeather all pos an negs wires to mini eletric plug
      CHEERS for havin a look see
      chrisb
        • 18266
        Things do start to be fun once lights are involved.
        Good trick with the tape to hold the part by the way.
        • JR
          • May 2015
          • 18273
          #184
          Great work Chris, I still can't believe it's a plane!
          • boatman
            • Nov 2018
            • 14451
            • christopher
            • NORFOLK UK
            #185
            THANKS Ian
            AN hi John yes beleive it or not its part of the plane an a lot more still to go togeather this may take a yr or so to finish how i want it but its moddelin thats all that matters
            CHEERS
            Chrisb
            • boatman
              • Nov 2018
              • 14451
              • christopher
              • NORFOLK UK
              #186
              HI ALL well i know i havnt shown a lot done on that tomcat an i havnt im afraid as been lookin at U TUBE build vids an no im not goin to do all that wheatherin an such but on one utube it shows a chap usein a red oil pen pics below as i will have a great use for this doin all them undercart doors on the tomcat an my superhornet so can anyone advise me where i can obtain one ?Click image for larger version
              for doin this red on them undercart doors edges Click image for larger version
              • boatman
                • Nov 2018
                • 14451
                • christopher
                • NORFOLK UK
                #187
                OH an another qeustion while i think of it as on them utube vids i see they use TAMYIA clear glue with a brush fitted to the lid an they just brush it on now how long does it take to glue properly an when just brushin it on the outside will it show up as a mess ?
                chrisb
                • stillp
                  • 8087
                  • Pete
                  • Rugby
                  #188
                  I've used Pilot acrylic paint pens from a high street stationery store Chris, but I don't know where you'd get an oil-based one.
                  • stillp
                    • 8087
                    • Pete
                    • Rugby
                    #189
                    Mr Google suggests Hobbycraft Chris. Is there one near you?
                    Edit: John has these in the shop: https://www.scalemodelshop.co.uk/gun...m-03-mr-hobby/
                    • Flip
                      • Jul 2022
                      • 257
                      • John
                      • Speyside
                      #190
                      Chris,
                      Talk about late to the party - just come across this thread and been reading with interest. Picked up some handy tips; thanks.
                      For me, there are three Tamiya glues:
                      1. Tamiya Cement (White Top)
                      2. Tamiya Extra Thin Cement (Dark Green Top)
                      3. Tamiya Extra Thin Cement - Quick Setting (Light Green Top)
                      With (1) the brush is quite big. Some folks cut some of the strands off to make a smaller brush. Personally, I prefer to apply using the tip of a cocktail stick. I have managed to get this on the outside where it's not wanted and it behaves just like Revell Contacta. So you can gauge the lumps that need to be addressed. Cure time is about the same as Revell/Humbrol.
                      With (2) the brush is fine and pointed. Fit the two parts together, dip the brush in the jar and dab the point of the brush into the seam. Capillary action will draw the glue along the seam. Dependent upon the length of the seam, repeat the previous step at regular intervals along the seam. Just be careful not to flood the seam by putting too much glue in. This is a really good glue for filling in seams where the original application has been insufficient. Keep putting the cap back on between uses as this stuff evaporated quite quickly.
                      With (3) the two parts MUST be fitted tightly together. It is useless for glueing parts together when there is a gap. It is like (2) above in that it spreads by capillary action but it dries like the clappers so you must return the cap to the bottle after every use. Having said this, it is a god-send. If you've got a couple of parts that you can't clamp/tape in position then simply hold them in place in the right orientation (keeping your fingers away from the glue line) and place a tiny dab of this glue on the tight seam line. You'll only need to hold it in place for 30 secs tops before you can let go.
                      Same as paint, there's a difference between drying time and curing time. I've found (2) will be dry and on-going usable after about 5 minutes whereas (1) will be at that state after 1 minute tops. But, to be fully-cured I would reckon these times go out to 48 hours and 24 hours respectively.
                      I have ended up in a guddle with both of the Extra Thins in getting them on the outside where I shouldn't have. But they don't make the mess that normal glues do because they are so thin. They tend to end up as a flat film of glue on the surface. The trick is to leave well alone, even if you spot it immediately. Just let it set and it is then easy to sand off as if it was never there.
                      With both of the Extra Thins, you dab at select points. This minimises any mess on the seams. I have seen folk brushing along the seams, in fact I have done it on quite a few occasions, but it seems to be a bit of a superfluous action as the glue is drawn along the seam by capillary action anyway. To me, this just increases the risk factor of painting neighbouring surfaces every time I wobble.
                      So, having read this thread so far and noticing that you're highlighting the increasing wobbles, trialling some (2) might be a useful experiment for you since it is spot-applied. The Tamiya product code is 87038 and John has it in the shop.
                      Hope this helps.
                      • Ancientmariner
                        • Feb 2018
                        • 859
                        #191
                        Looking smashing Chris!!!
                        • stillp
                          • 8087
                          • Pete
                          • Rugby
                          #192
                          Have you got those the wrong way round John? Surely the Extra Thin dries faster than the white top cement.
                          • Flip
                            • Jul 2022
                            • 257
                            • John
                            • Speyside
                            #193
                            Aaaarrrggghhh! That is defined as muppet mode :rolling:. Meaning one thing and not noticing I've typed something different.
                            You're absolutely right. I meant to write "I've found (2) will be dry and on-going usable after about 5 minutes whereas (3) will be at that state after 1 minute tops." i.e. the Quick-Setting will be QUICK!
                            Is there any hope? :rolling:
                            Please don't answer that :smiling5:
                            • boatman
                              • Nov 2018
                              • 14451
                              • christopher
                              • NORFOLK UK
                              #194
                              MANY THANKS Pete for info i'll have a look at it
                              chrisb
                              AN CHEERS John for your info also as ive bought some tamyia extra clear i think it is but never used it yet as this is my first plane build in yonks as my hms tiger build kept me goin for 5 yrs or so an still dont know if its finished due to eletrics but hope to find out when warmer wheather an a norwich boat club open day
                              cheers ATB AN NO I WONT ANSWER THAT LOL
                              chrisb
                              • boatman
                                • Nov 2018
                                • 14451
                                • christopher
                                • NORFOLK UK
                                #195
                                HELLO ALL well done a bit more on the big cat an im in the process of fittin in a flashin A/C light just under the nose cameras an here ive just threaded the led wires through the tiny hole but i removed the resistor firstly now gettin ready to glue it in postion Click image for larger version
                                an fitted an it flashes lovely as on my other tomcat i dint know about a ANTI -COLLISHION LIGHT FITTED HERE so this one is in the right place but i havnt glued the camera unit to gether yet as i may fit another led to shine out throgh the front glass Click image for larger version
