Nice Chris.
Boatmans Super Tomcat F14D Build
THANKS John yes now ive got to do a bit of thinkin ahead before i do any more may build the undercart an fit in the white leds landing lights
but im havin trouble findin stuff that i need as look everywhere an not find it only for it to turn up when im lookin for something else Aaaarrrrccc
chrisbComment
Just had a read through your build and you are doing some amazing work on a basic kit and adding life to it - well done Chris...Comment
CHEERS Mike for stoppin an havin a read through the thread
ATB
chrisb
THANKS Bri
yes keepin the ole grey cells busy thinkin ahead lol
chrisbComment
HI ALL
well still fitting in the leds an here ive fitted the front landing gear landing light an as i dint want the wires to be seen i just filed out the insides of the landing gear as this model is so heavy it need to have a metal bar fitted in the gear so had to do a bit of filein to get enough room for the wires to go up the gears centre so no wires are seen in pic below
AN HERE its all fitted to geather lovley but will the led still work ?
AN YES it does thank goodness but some of the other parts dont fit that are suppoced to fit on this landing leg so may leave them off as they are only smallComment
Originally posted by boatmanAN YES it does thank goodness but some of the other parts dont fit that are suppoced to fit on this landing leg so may leave them off as they are only small [ATTACH=CONFIG]n1218692[/ATTACH]
Nice work Chris, you're a braver man than me Gunga Din!Comment
WELL Doug OH YOU NAUGHTY BOY YOU LOL a leg pull it may be but think it must have some hydyrulics pipes somewhere on it
chrisb
ATB SIR
Chrisb
AN HI JR well yes i maybe gettin to clever for my own good lol but i like the challanges on these models to give it that just bit extera an the clever bit will be connecting all these wires up an gettin it all workin phew as its took me all today just to get the wires an the metal bar in that nose gear yes patiance is the name of the game most certainly an still months to go before i can try out tiger so this will keep me busy till then
cheers sir
chrisbComment
