Boatmans Super Tomcat F14D Build
  • Waspie
    • Mar 2023
    • 3488
    • Doug
    • Fraggle Rock
    #211
    Originally posted by Tworrs
    Looking good Chris, certainly up to your usual high standard.
    You missed 'inventive' as well as high standard.
    • boatman
      • Nov 2018
      • 14479
      • christopher
      • NORFOLK UK
      #212
      THANKS Garry an Doug cheers
      chrisb
      • JR
        • May 2015
        • 18273
        #213
        Chris. Where are you going to place the power source ?
        • boatman
          • Nov 2018
          • 14479
          • christopher
          • NORFOLK UK
          #214
          HI John in a wall mains sockect as its an adatapter from mains power down to 12v or through the range down to 3v so no probs
          cheers for your instrest JR an pic of the mains adapter below
          atb
          chrisb
          an the power comes through a posative an negative wires to a tiny plug that plugs into a tiny female socket fitted in the planes
          an if you look close the female plug can be seen in the planes fusalarge
          an here its plugged in to power the lights in my 1/48th tomcatClick image for larger version
          • scottie3158
            • 14202
            • Holbeach
            #215
            Hi Chris, sorry I haven't commented for a while. Great work on show.
            • boatman
              • Nov 2018
              • 14479
              • christopher
              • NORFOLK UK
              #216
              THANKS Scottie
              chrisb
              • Flip
                • Jul 2022
                • 257
                • John
                • Speyside
                #217
                Originally posted by boatman
                fitted the front landing gear landing light
                I didn't know you could do all this. Brilliant idea!
                • boatman
                  • Nov 2018
                  • 14479
                  • christopher
                  • NORFOLK UK
                  #218
                  THANKS FLIP YES done this no end of times but not on a 1/32 scale plane mostly on my ships fittin tiny leds
                  cheers for lookin in
                  chrisb
                  • JR
                    • May 2015
                    • 18273
                    #219
                    Thanks Chris, I was thinking where were you going to put the batteries ands switch, that's a neat connection point by the way.:thumb2::thumb2::thumb2:
                    • boatman
                      • Nov 2018
                      • 14479
                      • christopher
                      • NORFOLK UK
                      #220
                      HI again John well them small batt packs are good but if you have a lot of leds goin the batts soon run down then its a case of keep changein batt for new ones but havin the leds powered from the mains there is not that problem an i have the power adapter fitted to a timer switch an set so the planes light up only in the eveing an have it set for 15 mins on an 30 mins off so i dont send the missus up the wall lol but she says she like to see them goin an the timer also powers my big 1/350th USS ENTERPRISE all lit up so its a nice display goin an no batts to change hows that for an answer John ?
                      chrisb
                      • JR
                        • May 2015
                        • 18273
                        #221
                        Perfect Chris. :nerd:
                        • boatman
                          • Nov 2018
                          • 14479
                          • christopher
                          • NORFOLK UK
                          #222
                          HI CHAPS
                          well im still fittin in them landin lights on the main undercart an yes i know the real plane dont have any there but i want to light up the underside of the plane so the missles can be seen hopefully an buy gum this was a little blighter to build an nothin fitted so had to do a lot of filein down an its still not built as more bits to fit but at least i have the led in place an this took me all day today so more tomorrow an a couple of pics to show how complex trumpy it anwell im still fittin in them landin lights on the main undercart an yes i know the real plane dont have any there but i want to light up the underside of the plane so the missles can be seen hopefully an buy gum this was a little blighter to build an nothin fitted so had to do a lot of filein down an its still not built as more bits to fit but at least i have the led in place an this took me all day today so more tomorrow an a couple of pics to show how complex trumpy it anhave made of a should be simple undercart Click image for larger version
                          an here its near built but more parts to fit on Click image for larger version
                          • langy71
                            • 1950
                            • Chris
                            • Nottingham
                            #223
                            There's a well circulated internet 'quote' that gets used for all manner of things that at first glance seem an impossibility, it does the rounds on various social media regularly and would apply perfectly to this build...
                            it would go like this...
                            ''you can't put lights into that .. it's just not possible'', to which Chris would reply...''hold my beer''.....
                            looking fabulous Chris.. inspiring to say the least..
                            • JR
                              • May 2015
                              • 18273
                              #224
                              Well said Chris, that's Chris to a T
                              • Waspie
                                • Mar 2023
                                • 3488
                                • Doug
                                • Fraggle Rock
                                #225
                                As you mention it, mine is T no sugar!!!!
