Boatmans Super Tomcat F14D Build
  • boatman
    • Nov 2018
    • 14463
    • christopher
    • NORFOLK UK
    #316
    an now tryin a dry fit firstly to the nose part of the fusalarge an more cuttin an filein an yes i know this is what modelings all about but how much had to be done was redidalus an the wires for the lights can be clearly seen an still more to be added as i still havnt fitted the nose camers an red anti collishion light Click image for larger version
    • boatman
      • Nov 2018
      • 14463
      • christopher
      • NORFOLK UK
      #317
      an its now all glued in just got to hope the strb side will mate up ok Click image for larger version
      • boatman
        • Nov 2018
        • 14463
        • christopher
        • NORFOLK UK
        #318
        an yes it does but will be a battle to get it all closed up though so will have to glue an tape it togeather untill glue goes off as its very springy on each ends Click image for larger version
        • scottie3158
          • 14201
          • Holbeach
          #319
          Great work Chris, have you tried annealing the wire first it will make it a lot easier to bend to the shape you need. Or try solder wire.
          • boatman
            • Nov 2018
            • 14463
            • christopher
            • NORFOLK UK
            #320
            thanks Scottie an yes ive treid several different wires an due to the small size of these ejection handles it very difficult to get them to bend with out breakin but trumppy did not supply any an they are not listed in the destrickions so maybe this super tomcat did not have them fitted ? an i think i will try an fit a tiny hinge the front fusalarge to fit to the nose so it will hinge upwards like the real plane does
            • boatman
              • Nov 2018
              • 14463
              • christopher
              • NORFOLK UK
              #321
              HI GUYS well it was a battle to get this kit to fit togeather as been doin more filein an even some cuttin but this kit Click image for larger version
ID:	1222894 has put up a fight but its goin togeather wheather it likes it or not lol an here some pics with the radar an both nose sections now gluded togeather in MHOP i think trumpy have made this kit to complex an the bits not fittin an i could not fit the gatlin gun if i had just left how they made the covers as they needed a lot of grindin out to get it to fit over the gun oh boy nose cameras fitted with red flashin anti collishion light fitted in
              • boatman
                • Nov 2018
                • 14463
                • christopher
                • NORFOLK UK
                #322
ID:	1222896Click image for larger version
ID:	1222897Click image for larger version
ID:	1222898Click image for larger version
                • scottie3158
                  • 14201
                  • Holbeach
                  #323
                  Chris,
                  Your doing a great job.
                  • Stefee
                    • Feb 2023
                    • 780
                    • Stefan
                    • Hemel Hempstead
                    #324
                    Looking really good to me as an aircraft dumbell but the detail and painting look first class.
                    • boatman
                      • Nov 2018
                      • 14463
                      • christopher
                      • NORFOLK UK
                      #325
                      Chris,
                      THANK Scottie yes this bloomin kit is puttin up a fight but i think im winning
                      AN thank you too Stefee dont know what you mean by a dumbell ? but cheers on your comment about the detail an painting an should look fairly good if i can fit a tiny hinge in the nose so the nose can be lifted up to show the radar off
                      • Stefee
                        • Feb 2023
                        • 780
                        • Stefan
                        • Hemel Hempstead
                        #326
                        I mean I am as knowledgeable as a dumbell about anything that flies and how they are built.
                        • boatman
                          • Nov 2018
                          • 14463
                          • christopher
                          • NORFOLK UK
                          #327
                          OH i see Stefee well aircraft an warships have always been my main hobby over the last 60 yrs so i know a bit about both subject but not a lot lol but why dont you get a small plane an give it a try you may like it
                          ATB SIR
                          • Mickc1440
                            • 4775
                            #328
                            More great work Chris
                            • boatman
                              • Nov 2018
                              • 14463
                              • christopher
                              • NORFOLK UK
                              #329
                              HI Mick thanks yes the cat is comin on but i only hope the rest of the fusalrge is an easyier build as im hopein to fit a tiny hinge on the nose cone an fix to the fusalge so it can be lifted up to show that nice radar scanner but just holdin the nose cone near the radar to me the scanner looks too big to fit inside the nose cone if so then more fit probs as i think trumpy made it to be gluded in up postion if radar is fitted but if i want the nose cone in down postion then the radar cant be fitted just like the gatlin gun an if thats the case then i'll have to unclip the radar scanner an take it off an trim it down to a size where it will fit in the nose cone Aaaarrrgggg but im doin this today so will find out by tonight
                              ATB Mick
                              • colin m
                                • 8741
                                • Colin
                                • Stafford, UK
                                #330
                                I've just run through your thread from start to end. What a journey, she's a big old bird. Very interesting with all the electrics.
