Boatmans Super Tomcat F14D Build
hello chaps well im still strugglein on this model but one surprise the radar scanner did fit inside the nose cone as to me i looked to big so i just unclipped the radar scanner so it would be easyier to fit the nose cone hinge as i wanted it to be able to be rasied or in down position so radar can be seen so started to try an fit the small hinge an it was a total failure an it was fitted on the huh an it broke off easy while tryin to raise the nose cone an still more failures to come little did i know an jen was helpin me but again failure an she said give it up as im goin to to put the tea on so i was on my own again so i cleaned all areas up that had super glue on them an picked out a new hinge an start again any way terribble pic of fittin the hinge on the nose my worst work ever but i was learning how not to do it Aaaarrgghh an only a small thumb nail pics as not worth goin to full sizeAttached FilesComment
SO on the 5th attempt i went about fittin the hinge in a different way an with some new industrail super glue an this seemed to hold but i wasnt countin my chickens yet an i left it for an hr hopein this glue would hold the hinge in place when tryin to open the nose cone an i thought it would be nice to have a nice black nose cone so sprayed it in satin black an left it for a couple of hrs as i was gettin tiredComment
an when i felt better i went up to cave an had a look at what i had got an it looked reasonable so now for the 64000 dollar question will the nose cone be able to raise up an down an yes it did but only about 70% of nose up as the hinge was very tight against the fusalarge so its a partishall sucsses but now the radar should be able to be seen so im goin to fit the radar back on an call it quits an leave it while im aheadlol
oop: super glue i was usein dint have no holdin power so hunted for that industrial super glue on 5th atempt an im pleased to say thing went better then but jen says im stubbon as i dont like anyting to beat me as if it does happen i just down an think through what im doin wrong an most times a solution pops up lol
ATB Joe an thanks for stoppin an you puttin on a post i like that as sometime i get a hint from someone what i am doin wrong as we all are learning all our lives eant weComment
AN hi Scottie pleased you guys like my modelin but today im askin jen to hold the fusalrge upside down so i can open the nose cone to just clip the radar back into positon an then try it to see if the nose cone will miss the radar scanner when i attempt to open it an close so wheather trumpy has allowed for this to happen when they made the kit i will find out as the scanner will tilt down an up to hopefully allow the nose cone to open an close but im doubtfull as like on the gatlin gun covers they were not made to fit over the gun as to thick so i had to do quite a bit of grindin out of the plastic to get it to fit as like i think it was barry when he built his bomb cat he thinks they made the kit parts to be glued in their open poshtin if gun fitted an no gun fitted if you want to closeup the panel cover an i dont think they thought anyone would be crazy enough to whant the best of both worlds lol
but i suppoce im crazy enough lolComment
AN IVE just taped some tamyia tape to the nose side so it gives it a bit of strenght an not get knocked off an here she has eletric goin throught it an all light worked bar the front red anitcollishion led an i found that the red live wire had broken off the resistor but soon resoldered it an got it workin againComment
