Boatmans Super Tomcat F14D Build
  • langy71
    • 1948
    • Chris
    • Nottingham
    #421
    ahhh got ya, just a suggestion to stick in the back of your brain for the next time something doesn't line up properly...loving what you are doing with this though mate...keep up the sterling work.
    • boatman
      • Nov 2018
      • 14463
      • christopher
      • NORFOLK UK
      #422
      COR THANKS Chris yes yes i'll try an remember your very good idea as after this badly fittin tomcat kit ive got a 1/32 scale SUPER HORNET again by trumppeter an if its possible to bend because of a bad fit then i'll use your idea on it but i hope it will be a better fit an not a PITA of a kit like this one lol
      CHEERS MY FREIND an have a nice day to you an your wife
      ATB
      chrisb
      • Waspie
        • Mar 2023
        • 3488
        • Doug
        • Fraggle Rock
        #423
        Hi Chris, shouldn't you be wearing boxing gloves with this one!! It's putting up quite a fight!!
        That sticky out panel. Could you not shave off a little of the top to pull the section sticking out back into line. Or would that knock out the overall geometry of the engine panel??
        I've arrowed the bit I'm referring to!
        Doug
Name:	Screenshot 2024-05-18 at 11.01.47.png
        • Scratchbuilder
          • Jul 2022
          • 2689
          #424
          Morning Chris, I see you are having a fight with the engine cover... The regular move is as the other Chris said is boiling water. I have had a few problems with shapes that would not conform and my method is to use aluminium sheet or annealed brass sheet.
          I have some from Albion Alloys Code SM1 for the brass, but cannot remember the Ally code. But the thickness is 0.127mm and you could bend it over the plastic part and adjust once you have the basic shape, and then once you are happy with the shape add strengtheners to hold the shape in the form of flat strips....
          Here are some pics from the interweb (sources not named but thankyou)
ID:	1224522Click image for larger version
          I can enlarge and seperate the middle pic if you wish.
          Mike.
          • boatman
            • Nov 2018
            • 14463
            • christopher
            • NORFOLK UK
            #425
            Doug
            [ATTACH=CONFIG]n1224517[/ATTACH]
            HI Doug YES i am wearin B-gloves an goin for a knockout in the 10th round LOL IF IM STILL SANE LOL an yes i see what you mean but its the angle that the pic is taken at as its flush an ive done the cut in the panel to pull it in an no i cant angle it anymore as then the other end will be wrong an that slight gap at the bottom right is only half a mm as if it too tight then the engine panel will jam an not open so a slight gap is nessasary but thanks for pointing it out Doug as yes it does look a little high but its flush with the fusalarge so i think im gettin there now to try an fit them hinges an thats goin to be difficult but im enjoyin the fight or challenge of this models givinen me
            thanks Doug for havin a look an your question as to me it shows you are really studyin the model work an it makes me happy as you like chris ( langy) may think up an idea ive never thought of which chris did but i could not do
            CHEERS SIRS ATB
            chrisb
            [ATTACH]509026[/ATTACH]
            [ATTACH]509027[/ATTACH][ATTACH]509028[/ATTACH]
            Mike.
            OH Mike many thanks for these brilliant pics of the engine an covers im really please you have posted these as trumppter could have put on more detail on them engines than they have what a swizz but in my tomcat book it dont show this kind of detail brilliant pics but cant do anymore detail on my engines as if i do i may not get the panel to close up an yes enlarge the middle pics if you can as id really love them all enlarged as on a model like this you just cant have to many pics of detail more please Mike
            cheers my freind
            chrisb
              • 15692
              Well done Chris in getting that cover so much better.
              • boatman
                • Nov 2018
                • 14463
                • christopher
                • NORFOLK UK
                #427
                thanks jim as this kit just gets worst just as well ive got a little knowhow on modelin
                chrisb
                • boatman
                  • Nov 2018
                  • 14463
                  • christopher
                  • NORFOLK UK
                  #428
                  HELLO Chaps still havin a punch up with that big tomcat but im winning as got the engine panel to fit as good as i could an then fitted on the two mini hinges as can be seen in pic Click image for larger version
                  next A BATTLE to try an fit them to hinges to the fusealarge an then try an keep the engine panele in its correct postion on the fusealarge which turned out easy there as i just taped the panel in place an then glued the hinges to the fusealge with a heavy blot of glue to make sure the tiny hinges would not break off like the trouble i had with the nose cone an yes the cover looked a decent fit Click image for larger version
                  an yes it opens ok was sweatin here in case i got it wrong lolClick image for larger version
                  AN then just dry fitted in the engines to see if the workin can be seen through the engine cut out panel like the pics mike fitted in the build cheers mate an also these now have their air intakes
                  fitted
                  AN YES SUCCSESS here the engine panel is now in the open postion an its just how i envishiond it would be very pleased i am all thats needed now is lights fitted in to show up the engine which i will have a go at tomorrow
                  AN closed again so thats another idea thats work out fine even with all this fighting she down on the ropes lolClick image for larger version
                  • scottie3158
                    • 14201
                    • Holbeach
                    #429
                    Chris,
                    Nicely done mate.
                    • boatman
                      • Nov 2018
                      • 14463
                      • christopher
                      • NORFOLK UK
                      #430
                      Chris,
                      Nicely done mate.
                      HI Scottie cheers sir as yes this engine openin panel as near give me the collywobbles lol as yes the plastic of the kit is hard but tryin to fit that panel in to mate to the fusealage was a right bugger as the plane is quite big so it ends up bein floppy an then easy to make a mistake so the panel dont fit
                      ATB SIR
                      chrisb
                      • Flip
                        • Jul 2022
                        • 257
                        • John
                        • Speyside
                        #431
                        Excellent result Chris.
                        • boatman
                          • Nov 2018
                          • 14463
                          • christopher
                          • NORFOLK UK
                          #432
                          Thanks Flip im now sprayin the big cat in light grey an goin to give it two days for the paint to harden
                          cheers my freind
                          chrisb
                          • BattleshipBob
                            • 6792
                            • Bob
                            • Cardiff
                            #433
                            Lovely work Chris, impressed!!!
                            • boatman
                              • Nov 2018
                              • 14463
                              • christopher
                              • NORFOLK UK
                              #434
                              OH THANKS Bob mate an how you feelin now ?
                              • A_J_Rimmer
                                • May 2024
                                • 801
                                • Arnold
                                • North Wales
                                #435
                                Nicely done Chris, that worked well.
                                Arnold Judas Rimmer BSc SSc
                                ''Happiness is a Triple Fried Egg Sandwich with Chilli Sauce and Chutney''
