AN a pic here of how thin my new tomcat wingtip is at where the nav led will fit an its 2 mm but i have an idea formin in the old fossilied grey matter lol an today will have a go at seein if it will work an those who take modelin really serious dont look lol an a shot below this pic of the whole top part of starboard wing
Boatmans Super Tomcat F14D Build
CHEERS Jim ATB
ChrisbComment
WELL HI again Jakko an many thanks for your answer on the canopy seam but i just havnt got the confidence to do the seam as i will only bugger it up an spoil the model as guys like you have the knowagle on how to do it but i havnt a clue but OK say i was to try it what stuff would i need a list please below if poss ?
chrisb
2. A fine sanding stick.
3. Some wet and dry paper. 2000. 4000 and 6000 or even finer.
4. Some soft plasticine.
Form the soft plasticine and carefully push into the inside of the canopy to support it and make it easier to hold.
Carefully scrape the raised part of the seam away just shy of the surface.
Reduce the rest with light strokes with the finest sanding sticks you have. If you make it a tiny bit flat, that will go away again.
Warm soapy water and a firm sponge. Wrap the wet and dry around the sponge wet it well and gently smooth the area with ever finer grades of wet and dry.
You can finish with right down to 12000 grit.
Micromesh make a polishing set with various grades of abrasive cloth and a rubber block. John has then in the shop I think.Comment
1. A sharp flat blade.
ChrisbComment
When the shakes start - you stop then go back when youโre happy to continue.Comment
ChrisbComment
Looking forward to the lesson on LED's and of course the build.Comment
so i use their walls eletric sockets lol an i now dont take part in comps as i have won quite a few trophies an cups an such but have thrown them away as gettin a bit clutered up not bein big headed just fact an still got some cups an trophyies that have not thrown out as for my nimitz alone got 3 trophyies an have kept them as the model was special to me an you lookin forward to how i fit in leds in my models well i'll try an exsplain but im not that great a moddler as i think james an his tomcat have been built better than i can do but will see how the build goes an today im fittin in a 2mm blue led in the tomcats wingtip but very awkward as it so thin only 2mm an the led is about 2mm so goin to be touch an go if i dont get the shakes but thank for lookin in an hope you enjoy the build
ATB SIR
ChrisbComment
Originally posted by boatmanAn A SHOT of whats inside will show spruses in a little while
an a pic below of my tomcat book[ATTACH=CONFIG]n1213060[/ATTACH]Comment
Sorry Chris, I lost the beginning of this endeavour (no, not the ship... :rolling:) of yours.
I'll follow your magic with interest.Comment
chrisb
chrisb
AN HI GUYS well today i done 3 hrs work burein it out for a channell to take the led wires on that starboard wing to fit in the blue nav light an 1 hr tryin to glue the led to the glass nav lence god im shattered now nerves at breakin point an got the shakes but i have done what i set set out to achieve an first pic is where ive been burein out plastic in the very thin wing tip to take the wires for that 2mm led an i had to be very carefull doin this as i dint want to heat up the wing plastic as cause damage to the wing bottom
an a shot of the outer side of the wing to show i dint go right through as it was so thin
an here a shot of gluein the blue 2mm led to the back of the nav lence as ive done it like this so when i cut it of the glass sprues it wont go flyin into the ether to the carpet monster as i will be able to hold it by the wires an it will also help me to postion it when i come to glue it to the wing slot
AN THE BLUE LED works great it not as bright as this in real but my camera over exsposes the light an more pics tomorrow when ive recovered an calmed down a bit as i had 7 tries to get that led to glue to that nav lences as jen came up to model room to see i if i want help but thankfully i just managed on my own but had it not stuck on the 8th go then i would have asked for her help anyway the nice blue light workin next tomorrow to glue it in place an fix the twin wires in place in the wing
chrisb shattered lolComment
