Boatmans Super Tomcat F14D Build
  • Ancientmariner
    • Feb 2018
    • 859
    #106
    Great work Chris!!
    • Mini Me
      • Jun 2018
      • 10711
      #107
      Niiiiiiiice! :thumb2:
      • boatman
        • Nov 2018
        • 14451
        • christopher
        • NORFOLK UK
        #108
        happy new year all an well i had a little while at the bench before freinds came over yesterday an i have glued the starb wing together an buy gum there is a lot of parts to these wings an noticed that i think its a mold line or something as its sort of a swish line in the plastic an i only hope it wont show when painted as its smooth but as ive not built plastic kits for so many yrs im out of the swim anyway a pic of that horribble swish line in the plastic
        chrisb Click image for larger version
        • Ancientmariner
          • Feb 2018
          • 859
          #109
          Give it a rub with some 800 paper and then with 1000 for food measure and it will be grand Chris
          • boatman
            • Nov 2018
            • 14451
            • christopher
            • NORFOLK UK
            #110
            WELL James thanks for info i havnt got any sandpaper that smooth so it will have to wait till i can get some but more of jens freinds comin over later today so cant do much today but hope to have a good go on the other wing tomorrow
            CHEERS BOYO
            chrisb
            • Ancientmariner
              • Feb 2018
              • 859
              #111
              CHEERS BOYO
              chrisb
              In that case some toothpaste on a microfibre cloth or rag will work
              • boatman
                • Nov 2018
                • 14451
                • christopher
                • NORFOLK UK
                #112
                OK James do i sort of rub it in curtricular motions like polshin a car ? an will colgate toothpaste do ?
                chrisb
                • Ancientmariner
                  • Feb 2018
                  • 859
                  #113
                  chrisb
                  Yeah any toothpaste. Should just r move that as it's same as very fine cutting compound. Small circles and then clean with isopropyl after
                  • boatman
                    • Nov 2018
                    • 14451
                    • christopher
                    • NORFOLK UK
                    #114
                    what is isopropyl ? jAMES
                    CHRISB
                    • Ancientmariner
                      • Feb 2018
                      • 859
                      #115
                      Rubbing alcohol, clean it with that before you paint, removes any grease and crud from it
                      • boatman
                        • Nov 2018
                        • 14451
                        • christopher
                        • NORFOLK UK
                        #116
                        rubbin alcohol ? like wiskey or what as im totally out of my depth here as ive been teetotal for donkeys yrs so i dont get caught drinkin an drivein as so many of my freinds have over the yrs
                        chrisb
                          I would first try carefully feeling the area with my fingertip, and also with the tip of a fingernail. They’re sensitive enough that you should feel pretty much anything that lies proud of the surface, or is recessed into it. If you can’t feel anything, it will almost certainly be invisible after painting. If you’re not sure, you can always put a quick bit of paint over it (neatly) before continuing.
                          Chances are that what you see is nothing more than something like a bit of slightly differently coloured plastic that was among the granules that went into the mould, though. Manufacturers can and do recycle plastic (just not too many times, hopefully), or perhaps a darker bit of plastic was left in the machine somewhere from a previous moulding that used that colour. Or perhaps one that didn’t quite melt right.
                          • Ancientmariner
                            • Feb 2018
                            • 859
                            #118
                            chrisb
                            Get it off eBay, great stuff for a proper clean before you paint. You would not want to drink it! I always give a good wipe down with it even though I use gloves to handle kit.
                            • boatman
                              • Nov 2018
                              • 14451
                              • christopher
                              • NORFOLK UK
                              #119
                              HI James well looked at that mark on the wing closer rubbed it gently with my finger tip an its like Jakko said very smooth so save havein to buy that
                              isopropyl i'll leave it but thanks for your info very much apprecaited
                              chrisb
                              • peterairfix
                                • Jul 2012
                                • 11074
                                #120
                                If you're interested here is a link that might be of interest to you
                                Airfix, Electronic sets, Light set, Magic Scale Modeling, Plastic modeling, Revell, Scale Modeling, Tamiya, Trumpeter
