Cracking start Andy. Reinforces all the good things said about these new Airfix kits. That's a great looking cockpit, shows that you don't need aftermarket stuff to get a really good result. Glad the wing root join is good, so often that's where work is needed.
Airfix 1/72 Me410a
PeteComment
I was thinking sextant too but they tend to be square(ish) and the case tends to wooden!! Methinks it may be a conundrum we never solve. Unless someone knows different???
As an aside. It always amused visitors to our squadron when being shown around the helicopters. A common question was parachutes. When explained we never* used them but we did sit down on a life raft!! Then came the 'suppose you jump from the helicopter, count 1 - 1000, 2 - 2000 etc, look up and check life raft has deployed!!' Oh how we cringed!!!
I put an Asterix next to 'never' as all check flights of 10,000 feet required a parachute.Comment
As always with new Airfix, a cracking little kit
The 'problem' though, as you're finding Andy, is the tolerances of CAD stuff. There's no provision for paint 'thickness'!
Still, future modellers, should there be any in 2083, won't need to worry about the mould warping over the next sixty years!Comment
It’s not the life raft — that was stored behind the rectangular panel below the rear of the cockpit, just in front of the left gun mount:
[ATTACH]496936[/ATTACH]
Legend:
a. Inflatable boat container
b. Ejector spring
c. Hand lines
d. Inflatable boat
e. Cover
f. Container lid
g. Locking lug
h. Locating pins
i. Pusher (?)
There were handles on the left side of the cockpit, next to both seats, which would release the raft when pulled.
This is from a PDF of part 9 A: General Equipment auxiliary 1: Inflatable Life Raft of the Me 410 A-1 handbook.
BTW, as I read Andy wants to add the big gun, that’s covered by part 8AIt looks like you can only download one file per day from that site, though.
As for the scale, I'm finding it a whole lot less fiddly than the 1/48 Bf100!
Cracking start Andy. Reinforces all the good I think the belts things said about these new Airfix kits. That's a great looking cockpit, shows that you don't need aftermarket stuff to get a really good result. Glad the wing root join is good, so often that's where work is needed.
I think the belts came out a bit chunky but I'm happy with the overall look of the cockpit.
Thanks Jakko, handy link that.Comment
[ATTACH=CONFIG]n[/ATTACH]
Legend:
b. Ejector spring
c. Hand lines
d. Inflatable boat
e. Cover
f. Container lid
g. Locking lug
h. Locating pins
i. Pusher (?)
BTW, as I read Andy wants to add the big gun, that’s covered by part 8A :smiling3: It looks like you can only download one file per day from that site, though.
Apart from materials, the packing is not dissimilar to how it was done in the 80's/90's. ( I wonder if they used French chalk when packing the rubber elements to avoid them sticking?)
Not being a German speaker I'm unable to determine that from the document.Comment
The instructions for folding up the boat (pages 10–13) really only talk about the importance of getting all the air out (including mentioning instead of three or four men lightly pressing the boat flat, a vacuum cleaner can be used for this) and how to fold it. No mention of chalk.
Aha, later on, in chapter IV (p. 22):
Unabhängig davon, ob das Boot im Flugzeug eingebaut oder auf Lager gehalten wird, ist es alle 4 bis 6 Wochen schwach mit Luft aufzupumpen und mit Talkum einzureiben. Es ist ratsam, auch durch das Ventil Talkum einzublasen.
Edit: Just remembered that I can now download part 8A as wellNo idea what bits of the gun are included in the kit, but for general interest, here’s how it fit in the real plane:
[ATTACH]496960[/ATTACH]
1 5 cm BK [Bordkanone, lit. “[On-]Board Cannon”, more loosely, “aircraft gun”]
2 Front mounting
3 Rear mounting
4 Ring-shaped magazine
5 Weapon mount
6 Fittings on seat and weapon mount
7 Spar reinforcement
8 Hoisting rollers on seat and weapon mount
9 Hoisting rollers on main spar
10 Hoisting rope
11 Hoisting eyes on the weapon
12 Storage tube for hoisting rope
13 Pneumatic belt feed
14 Pneumatic feed
15 Pneumatic charger
16 Fuselage panel
17 Spent-case chute
18 Fittings on main spar
19 Installation plate
20 Strut
21 Transformer for igniter
22 Plug connector P 264/P 800
23 Electrical junction box 5 cm BK
24 SZKK 4 [whatever that may be]
25 Warning light P 267 (now visible symbol connected to SZKK 4)
26 Distributor V 28
27 Circuit breaker P 263
28 Relay P260, P 266 and P 3
29 KG 13 B [?]
30 B-button [firing button, I assume?]
31 3× EPD-101 A [?]Comment
“Irrespective of whether the boat is stowed in the aeroplane or held in reserve, every 4 to 6 weeks it is to be lightly inflated with air and to be rubbed with talcum powder. It is advisable to also blow talcum powder in through the inflation valve.”
Edit: Just remembered that I can now download part 8A as well :smiling3: No idea what bits of the gun are included in the kit, but for general interest, here’s how it fit in the real plane:
2 Front mounting
3 Rear mounting
5 Weapon mount
10 Hoisting rope
14 Pneumatic feed
16 Fuselage panel
17 Spent-case chute
20 Strut
26 Distributor V 28
29 KG 13 B [?]
31 3× EPD-101 A [?]
We used the same technique when packing our rafts. Suck all the air our with a good old ‘Henry’, plug the hole, even if it did have a non return valve!!!
Then French chalk, fold iaw the relevant AP, (aircraft publication). Then try and fit it into a fibre glass shell or canvass back pack.Comment
Thanks Ian & Lee. I'll certainly be looking at more of these newer Airfix kits in the future.
I've had a couple of issues today but both were self inflicted. Firstly I broke the side mounted machine guns in half while clipping them off the sprue. I managed to fix one but lost the others barrel, so have added a bit of stretched sprue. Not perfect but they are so tiny I'm hoping no one will notice :smiling5:
Then the biggy. The canopy is in 3 parts and while cementing it together I managed to get a load of gluey fingerprints on the inside!
So that was a couple of hours this afternoon, sanding and polishing. It's looking salvageable as I break for food, will have another go at it tomorrow.Comment
