Rick’s 1/24 Airfix Hellcat
Just finished: Airfix 1/48 Stuka & Airfix 1/72 Sea King HC4.Tags: None -
It will be a fishead kite but from the Pacific Area of Operations. I have an aftermarket paint mask set; first time I will attempt painted on markings.On the bench: Airfix 1/48 Sea King HC4, Revell 1/24 Trabant.
Just finished: Airfix 1/48 Stuka & Airfix 1/72 Sea King HC4.Comment
Rick
Will follow with interest......before you go much further you might want to check out Barry's build of this.....it went in the bin....there were a number of fit issues including a warped fuselage.....not sure if he got a dud kit though.
ATB
Rick
ATB
I got the etched seatbelts but might just use the kit parts instead.
The cockpit is almost ready for closing up the fuselage. All painted, decals applied and a wash.
Now...the fuselage. It fits together nicely with the exception of the underside just in front of the access panel; there’s a big gap. No amount of squeezing or clamps would close this, not even filing off a large area of the frame behind the cockpit bulkhead. My best option was to cut out a section of the frame so I could squeeze it close enough for the fuselage halves to be glued. That will be for another night.
I’ve also been building the wings and centre box section, these too are not the best fit.
This kit is flirting with the shelf of doom.On the bench: Airfix 1/48 Sea King HC4, Revell 1/24 Trabant.
[ATTACH=CONFIG]n1216391[/ATTACH][ATTACH=CONFIG]n1216392[/ATTACH]
[ATTACH=CONFIG]n1216396[/ATTACH][ATTACH=CONFIG]n1216397[/ATTACH][ATTACH=CONFIG]n1216398[/ATTACH][ATTACH=CONFIG]n1216399[/ATTACH]
This kit is flirting with the shelf of doom.Comment
A fair bit of progress since my last post. The cockpit is done and the fuselage put together but it needed a bit of persuasion, the surgery on the frame helped close the gap.
However, I had to take a bit of time off from this when it came to the wing centre box section attachment. Some alignment issues in earlier steps caused a few gaps between the wings fuselage join. I finally worked up the will power to join these two bits together.
Steady work on the engine has been continuing, it’s very detailed.
The pesky wing joins.
The engine build first steps.
And some of the sub assemblies painted and ready for build up when dry.
That’s probably all I’ll get done for a couple of weeks; a work trip to Amsterdam this week then Heathrow the week after will take priority☹️Attached FilesOn the bench: Airfix 1/48 Sea King HC4, Revell 1/24 Trabant.
