Good afternoon all
As you can see from the title, one will be done as an A-8 fighter version and the other as the F-8 Jabo version. These are for a Wurger GB on the other forum I frequent but I thought I would share them with you all
These are actually the first ever 190s I have ever done. They will both be done 'wheels up' in flight as their supposed to be for the little battles Junior and I have.
The original release was the A-8 in 2013 (my one is apparently a 2018 rebox for starter kit purposes). The F-8 was released in the same year, with the added parts for the bombs and racks, albeit the payload is apparently a bit limited.
The A-8 was a £7 Aldi purchase from this time last year, although I see it doesn't have the full decal sheet i.e. no stencils like the F-8. Nevertheless, when you consider the pair cost me only £18, you can't really complain - even allowing for the minor shortcomings noted by most reviewers.
I've also bought an AM set of decals for the Jabo but I'm not sure if I'll use them; we will see. I have also bought some canopy masks as usual.
Below is the usual set of pre-build taster pics. However, as the sprues are identical (save for the bomb sprue) I have only taken shots of the F-8 sprues. The destruction images of the paint job are for the F-8 version.
AlanG - I know they're the wrong scale in your eyes but I do know that you like a Wurger!
ACW as usual.
Useful links:
www.scalemates.com/kits/airfix-a02066-focke-wulf-fw190-f-8-a-8--173949
www.modelingmadness.com/scott/axis/previews/airfix/a02066.htm
www.hyperscale.com/2014/reviews/kits/airfixa02066reviewmd_1.htm
reviews.ipmsusa.org/review/focke-wulf-fw-190a-8
The Airfix A-8 decals are top right; the F-8 are at the bottom.
These are the AM decals for the F-8.
I wish the pitot tube on the starboard wing had been done as separate piece.... that is just asking to be snapped off! :cold-sweat:
ACW as usual.
Useful links:
